The Newman Matrix
Started by gaby de wilde, February 02, 2008, 08:00:33 AM
Koen1
well, it is quite nice, yes. :)
I like this design: http://www.magneticpowerinc.com/pdf/MPI-patentapplication.pdf
but I'm unclear on whether or not this does indeed produce OU...
I think it might, because this seems to be the "Genie technology" they refer to
all over their website, and they very clearly claim that it is OU/FE.
Have you seen this before, or do you know more about it?
(I know the company itself does not give any additional info unless you
sign a non-disclosure agreement, so it might be hard to get fresh data on it...)
gaby de wilde
I don't know anything about magnetic power inc. The patent application is interesting but not much related (I think?)
There can't be just one working device. Surely there are hundreds of ways to pull it off. perendev makes them in the hundreds of kW. That almost makes it impossible to find a good place for it but I bet they have good reasons for it. :-)
I put some links here.
http://magnetmotor.go-here.nl
I've made this illustration of the 27 (3 X 9) fields interacting.
Gives a good picture of how intense 27 fields really is. :-)
blog  | papers | tech | inventors  | video
gaby de wilde
try look deep into the image. :D
gaby de wilde
I was thinking of a Newman matrix powered wind tunnel.
Try think really small or really big.
The idea is to have a lot of magnets move in sink with a lot of coils.
One can pulse the rotors if there is not enough wind to push them around.
wind + pulse is more then just a pulse just like wind + pulse is more then just wind wind
The axle friction however only applies one time.
We have the 2 whole machines but we only have half the friction left.
In the previous post I used (only) 3 coils to build 2 Newman machines in stead of 4.
Then there was mention of a 3X3X3 block of axles, there 4 coils is enough per row in stead of the usual 3X2=6 (normally the Newman machine has 2 coils)
We saved 2 coils per row, over the other angle we had more as one Newman machine on the same axle.
Using (only) 3 machines per axle we may (already)  scrap 4 bearings.
The normally lost flux changes from the 27 overlapping fields generates extra flux 26:1 that means looking at one coil the other 26 coils combined have more influence as the coil it self.
If you pack the coil in even more external fields then it's own power will merely be a seed to the sum.
I thus so on further more as a result there of now suggest to also use those "virtual" axles to attach wind power harvesting means in order to accomplish more massive part savings and to seed that huge energy gain we was suppose to find in some configuration for that was the task of this forums!
;D
gaby de wilde
This is suppose to look like a grid of wind tubes.
It should go on a rotatable platform offset from the center so that it aims it self at the wind.
