Thane Heins Perepiteia.
LarryC
Quote from: RCH on May 09, 2008, 12:15:18 AM
P.S.  Larry, didn't see your post until after I made mine, and I agree.  But really -- for OUman to implode so publicly ...I guess its hard to get competent help all over these days ....      :)
Indeed,
When OUman first showed up I was a little concerned that Thane's project may have been downgraded to a lower risk level. After all, sending an obvious spook newbie to face PB veterans was disconcerting. OUman started out slow and ignorant (agreed due to lack of training)  but has recently googled some knowledge and distraction ability, seems to be some what intelligent. What I don't understand is why there is so many intelligent minds around with such weak character? Are we missing something else that is causing this problem?
Regards,
Larry
PS: I continue to be amazed by your vast knowledge.
RCH
Larry,
Google is MY friend too ....             :)
RCH
hoptoad
There's been a lot of theoretical posturing going on here in last few pages. Now for something completely different!
Does anyone have any more empirical data gleaned from their setups yet?
It would be good to gather some data from all you doers out there at the moment.
Empirical data is really needed (at least by me) to better understand the underlying fundamental principle/s of this effect. (IMHO - oops is that posturing  ??? )
Could one of you please try the following experiment. ?
Rectify to DC and filter the HV coil O/P. (either directly or on the stepped down side of a transformer load if you're using one.)
Create a small panel of series connected 1 ohm resistors up to say 40 ohms. (40 resistors, or more if you want.)
Use 2-5 watt rated resistors to avoid blowing them with too much heat if your O/P is relatively high.
Starting at one end of the 40 ohms panel, Put a DC ammeter (high current setting) in series with the panel and one end of the O/P.
Place a voltage meter across the panel at the same end and the other end which is also connected to one end of the O/P.
Take incremental O/P voltage and current measurements, starting at Open/C, then connecting the panel at 40 ohms, and then reduce the resistance, one ohm at a time, from 40 ohms down to zero ohms (Short/C).
Also take incremental voltage and current (or direct power measurements using an RMS watt meter) of the input to the prime mover at the same time.
Take a particular note of the point at which the rotor begins to accelerate.
Take RPM readings at every incremental step from O/C to 40 to S/C
Note the number of magnet pairs to determine sine frequency for a given RPM
Measure the inductance of the coil/cores if you have the instrumentaion to do so.
Note the DC resistance, gauge and number of coil turns (where possible if your winding them yourself)
Note the core material and style, (solid, laminated,  granular, alloy) shape, length, width, weight, etc.
All the while, if you have an oscilliscope, then create a pictorial of the incremental results.  :)
Publish your results please  :D
Especially oscilliscope shots of voltage and current traces,.  hmmm a dual trace synchronous display of current and voltage would be really great.  ....... hmmm I see I've got a wish list going here... I hope it's not too much I'm asking for...  ???
Cheers all .. KneeDeep  :)
OilBarren
QuoteWhat I don't understand is why there is so many intelligent minds around with such weak character? Are we missing something else that is causing this problem?
Regards,
Larry
YES - STOP DRINKING THE TOXIC COOL-AID.
Thane
OilBarren
A RECENT ARTICLE REQUEST TO TYLER HAMILTON AT THE TORONTO STAR
IF ANYONE IS INTERESTED I CAN SUPPLY ALL THE DOCUMENTS AS PROOF.
Thane
CHUMPS AT THE PUMPS
Dear Tyler,
Can you please do an article on gas pricing and how the Feds charge about 50 cents/litre in tax and that we could all be paying 70 cents/litre if we didn't elect criminals.
I sent you some information a while back on the Constitutional Divisions of Power between the Federal and Provincial Legislatures - and how the Provinces have EXCLUSIVE RIGHT TO DIRECT TAXATION - well gas tax is a form of DIRECT TAXATION.
The Supreme Court of Canada has upheld in (1950!!!) that there is NO PROVISION for shared powers between the Feds and Provinces - so if a man has EXCLUSIVE RIGHT to make love to his wife - nobody else can share it right?
My platform in BOTH ELECTIONS was and still is that - the Federal Government is a criminal organization - and you support them with your ignorance everytime you go to the pumps and pay "hidden" and "illegal" tax.
When I presented this info to MP elect - Cheryll Gallant she said, "I know the truth, Stockwell Day knows the truth but if we told Canadians the truth we wouldn't get elected."
I gave this tape recorded info to the RCMP, PM Paul Martin and every MP in Ottawa including Jack Layton but they are all playing us for chumps at the pumps
Thane
