Thane Heins Perepiteia.
markzpeiverson
Quote from: LarryC on May 17, 2008, 09:53:53 AM
@i_ron,
A few questions to compare performance:
1 What are you using to control the speed?
2 What size are your magnets? I got better results with 1/8 cupped neos, then with 1/4 neos on back a cup.
3 What is the weight of your new rotor?
Thanks,
Larry
@i_ron:
4. What's the new rotor made of???
We dance round in a ring,
And suppose...
But the Secret Sits in the middle,
And knows.    --R.Frost
i_ron
Quote from: aether22 on May 16, 2008, 05:44:58 PM
Glad you got positive results, but it is odd that you need such speeds.
Aether,
If you look back at Thanes chart you will see that he was running at 3400 RPM.
Ron
i_ron
Quote from: OilBarren on May 16, 2008, 06:57:12 PM
NICE WORK THERE ROCK'IN RONNY HACKJOB!
snip
AT ANY RATE I SUGGEST "SMALLISH" MICROWAVE TRANSFORMERS FOR ANYONE ELSE WISHING TO TRY THIS AT HOME.
Thane
Glad you like it Pal,
I feel I am in hysteresis mode now, but one step at a time I guess?
What is the gauge of the wire in that single coil, the one possibly for Aether? is that meter set on ohms?
I had seen the Red Green vid, pretty cool, I can identify with that....
Ron, basking in the spring like coast weather
Nali2001
Hi sir I-Ron
You don't know me  8) but I heard a lot about you! Good quality replications!
I also made a thiny some time ago. See it here:
http://www.krystyna.nl/Machine/RevUpUnderLoad.wmv
You see it accelerate to double rpm while doing a real 50watt load.
No additional (above idle) power is being fed to the motor during the vid.
What ya think?
Steven.
The sanding man
i_ron
@i_ron,
Thanks,
Larry
Hi Larry
1) Variac (variable transformer)
2) I am using the Lee Valley 1/8th by 1" neo's, and stacked two high (12 magnets for a six station
wheel)  The cup is home made and is 1 1/8th bore and 3/16th deep...(ha ha, those ottawa moguls
though they could legislate us into metric...) with a plastic bush around the two magnets.
3) It is made as a steel fabrication, machined all over and "sort of" balanced, it weighs 2050 Kg's
Ron
