Thane Heins Perepiteia.
0 Members and 27 Guests are viewing this topic.
LarryC
Quote from: CRANKYpants on October 19, 2008, 06:39:29 PM
DEAR LARRY,
DO YOU KNOW ANYTHING ABOUT THIS...?
T
No knowledge, he believes that God told him to be president, and no one knows what he thinks God is telling him now.
Regards, Larry
CRANKYpants
Quote from: LarryC on October 19, 2008, 07:09:27 PM
Regards, Larry
DRINK THE KOOL AID GW
DRINK THE KOOL AID...!
T
Gustav22
Quote from: CRANKYpants on October 19, 2008, 09:59:46 AM
...SO THE "CAPACITORS" CHARGE AT RESONANCE WHEN THE INDUCTIVE REACTANCE AND CAPACITIVE REACTANCE CANCEL EACH OTHER OUT... AND THEN DICHARGE THROUGH THE COIL'S DC RESISTANCE TO PRODUCE A MAGNETIC FIELD ??? ...
Hi Thane and all,
I am sorry, but I have no knowledge about how or why this works.
However, your idea to use the said winding style for a primary in your transformer project may be a good one.
After all the inventor holding the patent - his name is Pavel Imris and I don't know him but only read about his work in this forum - also holds an older patent on a special transformer (German patent DE19927355).
The primary of this transformer consists of a capacitor - made of two stacked foils which he calls 'ribbon capacitor' - wound onto the transformer core.
So one can see that in the older patent he used a capacitor made of foils as the primary winding, whereas in the meantime he seems to have found out, that he can achieve the same effect by 'simply' winding two parallel copper strands and adding a capacitor to each end of such a double helix.
His old patent for the transformer is here:
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DE19927355&F=0
Note: Only the abstract is in English, all the other text is in German only.
Another overlap between the older transformer patent and the new patent for the special 'capacitive winding style' is the following:
- in the old patent he claims that due to the foil-capacitor-winding, the reacitve/wattless current can be exploited as real current.
- in the new patent he claims (claim 007, page 2:)  "... Ferner ist es Aufgabe der Erfindung, den Blindstrom in der kapazitiven Wicklung in mechanische Wirkleistung eines Elektromotors umzuwandeln "
which translated would be
"...it is furthermore a task of the present invention to transform the reactive power in the capacitive winding into real mechanical work performed by an electric motor."
money for rope
CRANKYpants
DEAR EVERYONE,
I EMAILED THE FOLLOWING LETER TO EVERYONE I KNOW - INCLUDING MY MEDIA CONTACTS, SO LET'S HOPE THERE IS STILL TIME FOR "GOD TO BLESS AMERICA" WITH PEACE.
When I think of more to do I will do it.
Thane
How to Avoid the Planned Martial Law & Election Cancellations
due to the "Economic Crisis" in the U.S.A.
The so called "Economic Crisis" in the United States will be used as a pretext to initiate Martial Law and a cancellation of the upcoming elections, (see below, Martial Law video).
There is a way to avoid this by reading, viewing and understanding the simple and easy to understand explanation on How the Perepiteia Generator High Voltage Coils Cause Acceleration (also provided below) and most importantly - sharing it with your media..
The energy and complimentary torque provided by the generator's High Voltage Coils comes a no cost to the system and as a result is FREE energy. Please request Test Data proof if you require it.
According to the video the U.S.A. has about 1 week of freedom left if that and Canada is not far behind.
Martial Law Video
http://www.organicconsumers.org/articles/article_15028.cfm
HOW GENERATOR HIGH VOLTAGE COILS CAUSE ACCELERATION
At the critical threshold speed or frequency (dictated by the coils impedance) the HIGH VOLTAGE COIL ceases to act as an INDUCTOR (storing energy in the electromagnetic field and producing a Lenz's Law repelling action to the approaching magnetic field) and begins to act as a CAPACITOR (storing energy in the electrostatic field between the wires).
When a North Pole magnet approaches a HIGH VOLTAGE COIL above the critical threshold speed/frequency a North Pole repelling magnetic field as per Lenz's Law is not produced because the coil's impedance has impeded the current flow within the coil sufficiently. Voltage is built up in the coil and stored in the electrostatic field like a capacitor.
When the North Pole magnet is TDC - Top Dead Centre - neither approaching nor receding away from the coil - the coil's stored voltage, which is now at a maximum, is released through the coil's DC resistance and a magnetic field is produced according to Lenz's Law  (at this split second at TDC the AC sine wave is changing direction and as far as the coil is concerned frequency is briefly 'zero' and coil impedance is zero so current is allowed to flow - thus producing a delayed North Pole magnetic field which now pushes away on the receding magnet and simultaneously attracts the approaching opposite South pole on the rotor. Video : FREQUENCY VARIATIONS & MULTI-LAYER HV COIL ACCELERATION
http://www.youtube.com/watch?v=YReGJEMmkJA
All Potential Difference Inc. videos:
http://www.youtube.com/profile_videos?user=ThaneCHeins
Sincerely
Thane
Thane C. Heins
President Potential +/- Difference Inc.
"Men occasionally stumble over the TRUTH, but most of them pick themselves up and hurry off as if nothing ever happened..." - Winston Churchill
"Ignorance is NOT Bliss" Videos
http://video.google.com/videoplay?docid=-1656880303867390173&hl=en
Http://www.zeitgeistmovie.com/
allcanadian
@Gustav22
Quote- in the old patent he claims that due to the foil-capacitor-winding, the reacitve/wattless current can be exploited as real current.
Wattless current LOL, if you only knew what a contradiction in terms that is. Here is an overview of the Pavel circuit operation.
The AC source provides current moving from left to right (point 6 to 7 in circuit) current in conductor 2 charges capacitor 3, current in conductor 1 charges capacitor 4. Next when AC source 5 current alternates the current direction is from right to left (point 7 to 6 in circuit), the charged capacitor 3 is now in series with the source 5 through conductor 2, the charged capacitor 4 is now in series with the source 5 through conductor 1. This series potential in conductors 1 and 2 is now double the source potential. As I see it the main benefit of this circuit is to use the capacitance to counteract inductive reactance. But the term inductive reactance should be clarified to understand why capacitance is needed. An induced magnetic field in an armature acts like a flywheel, the armature will oppose a current rise and a current fall in the armature. This produces a phase lag when a load is attached to the motor, when the current is supposed to be increasing in the armature it is opposed by the inductive nature of the armature-- this circuit adds a charged capacitance in series with the source to increase potential thus current flow counteracting the opposition. When the current is supposed to be decreasing in the armature the inductive nature of the armature opposes this decrease by raising its voltage---this circuit adds a capacitance to store this increasing voltage and resist the voltage rise proportionally as a capacitor so often does. The function of the capacitance is to make the current source 5 see the inductance in the armature as nothing more than a small capacitance having very little resistance. The question I would ask is---- If the motor current and voltage rise and fall is perfectly matched with the source generator where is the so called "work" involved to drive the motor? Because the only work the AC generator ever performed was fighting to maintain it's current and voltage levels equal with that of the AC motor, which the capacitance is now doing for the generator. It should be obvious that the capacitance must vary with the AC motor load ---- Or we could just vary the inductance to match the capacitance which would be the better choice, use a larger capacitance than is required and a variable inductance.
Just recently I have developed a circuit to prove this point, I have found that a DC permanent magnet motor can be fully loaded and the only losses are ohmic resistance and thermal losses---What we consider as energy,the current flow, the watt-seconds are recovered-- in which case I had to ask what is it exactly that is powering the load?. I am posting this here because I think old crankypants is going to kick some ass in the near future and we should help him in any way we can.
