Thane Heins Perepiteia.
Kator01
Hi i_ron,
what did you do ? Can you show a simple hand-drawing of your transformer-setup and describe your findings ?
Measurements ? Is this a microwave-oven-transformer you have shown in your picture ?
I have done some tests with a flyback-transformer using 20 turns for a double-string primary-coil and about 800 turns for the secondary. First tests with a rectangular waveform have not been very successful . Now I will develop a sinus-waveform-oscillator for the range 5 KHz to 30 KHz for further tests.
Kator
Nali2001
Hi there Thane,
To support ya case, here is a video showing the acceleration effect based on a minimum speed threshold.
Indeed, too low speed and ya get no acceleration. Go over the speed turnover point and there is acceleration.
http://www.krystyna.nl/Machine/RPM_test.wmv
Regards,
Steven
CRANKYpants
SO I KNOW I AM A DORK - BUT NOW I AM A VERY CONFUSED DORK?
(while trying to track down Steve's website)
http://www.electro-tech-online.com/alternative-energy/85076-free-energy-generator.html
--Latest replication video-- http://www.krystyna.nl/Machine/RPM_test.wmv
A generator which accelerates under load, LOL, how original. The generator shown above is a good example of the new technologies which will utilize the electric force to improve efficiency. Quite simply--- Lenz's law has no application when energy is generated and stored as capacitance, an electric field. In the near future Mr.Heinz is going to realize that the HV coil can be precharged to any level by utilization of high voltage/high frequency impulses. He will also understand that there is no such thing as overunity, you cannot violate the conservation of energy. The supposed "extra" energy utilized was always present but we have never set the proper electrical conditions to utilize it.
AC
CRANKYpants
Quote from: Nali2001 on October 27, 2008, 03:37:26 PM
Hi there Thane,
Regards,
Steven
SO NOW I AM REALLY FUCKED UP?
SORRY STEVEN - I CAN'T OPEN YOUR MOVIE FOR SOME REASON.
IS IT A JEST AS WELL OR IS IT SINCERE?
Thane
CRANKYpants
OK NOW I GOT IT TO WORK  :)
BUT I AM NOT TERRIBLY CONVINCED... :-\
IS IT THE SAME VIDEO SHOWN PREVIOUSLY?
LAMINATED CORES OR SOLID IRON?
HIGH CURRENT WIRE?
IF THEY ARE SOLID IRON (AND HC WIRE) THE CORES WOULD HAVE A LARGE HYSTERISIS EFFECTS WHICH WOULD DIMINISH UPON SATURATION AND CAUSE ACCELERATION SO IDEALLY YOU WOULD HAVE TO MONITOR OUTPUT CURRENT AS WELL.
I AM OPERATING AT LOW POWER LEVELS BECAUSE I AM VERY COGNISANT OF CORE SATURATION AND TRYING TO AVOID IT WITH LAMINATED CORES.
T
