Thane Heins Perepiteia.
Groundloop
Heinstein
Quote from: Groundloop on February 22, 2008, 02:31:39 PM
Thane,
Am I correct in this drawing?
Groundloop.
THE DRUNK PERSON WHO WOUND YOUR STATOR - FORGOT TO WIND THE ROTOR BEFORE HE PASSED OUT - BUT OTHERWISE IT'S PRETTY CLOSE. YOU SHOULD ADD THE ROTOR FIELD IN THERE AS WELL SO YOU ARE CLEAR.
Groundloop
Thane,
I'm trying to be serious here and so should you! I'm trying hard to find out the most about your setup and my best way of
understanding is with drawings. They are not so very good, I admit that, but I think they show the most basic circuits.
(BTW: I do not drink alcohol at all.)
I did not draw any windings on the rotor because MY motor is an Induction motor. The rotor is the only moving part and has
no copper windings. The rotor is made of laminated soft Iron.
Have you done any measurements of the magnetic flux coming out of your motor axle?
I did a test where I connected a 450 turn coil (Ferrite core) to my DVM. When I placed the coil close to my motor axle (motor running) then I got 0,003 VAC open coil voltage. This flux is so small that it could well be from the internal motor coils. I do not have a magnetic flux meter so if anybody on this forum can do the test I will be grateful.
Groundloop.
aether22
Quote from: Heinstein on February 22, 2008, 06:45:34 AM
PAY ATTENTION TO THE VIDEOS AND YOU CAN'T FAIL. JUST TAKE ADVANTAGE OF YOUR ROTORS LEVER ARM TO INCREASE TORQUE - DON'T MAKE IT TOO SMALL.
What is the minimum you have tried successfully/believe works.
Heinstein
I'm trying to be serious here and so should you! I'm trying hard to find out the most about your setup and my best way of understanding is with drawings. They are not so very good, I admit that, but I think they show the most basic circuits. (BTW: I do not drink alcohol at all.)
YOUR DRAWINGS ARE GREAT, ACTUALLY WE CAN BE SERIOUS AND HAVE FUN (JOKE A LITTLE) AT THE SAME TIME. BLACK SUITED OIL HITMEN COULD TAKE ME OUT AT ANY MOMENT SO PERMIT ME THE ODD ATEMPT AT HUMOR PLEASE.
I did not draw any windings on the rotor because MY motor is an Induction motor. The rotor is the only moving part and has no copper windings. The rotor is made of laminated soft Iron.
HOW DOES YOUR ROTOR DEVELOP A MAGNETIC FIELD IF IT IS NOT INDUCED BY THE STATOR?
IS YOUR MOTOR A PERMANENT MAGNET ROTOR?
YES WE CERTAINLY DID IT WAS 25 GAUSS @ 300 RPM - AND IT INCREASES WITH ROTOR SPEED INCREASE.
YOUR VOLTAGE IS PROBABLY WAY TO SMALL TO PRODUCE A CURRENT AND MAGNETIC FIELD LARGE WITH ENOUGH FORCE LARGE MAKE INTO YOUR ROTOR? GOTTA GO A BLACK VAN JUST PULLED INTO MY DRIVEWAY!
Groundloop.
[/quote]
