Thane Heins Perepiteia.
hydrocontrol
Quote from: baroutologos on May 05, 2009, 10:21:42 AM
Hi Hydro,
Yes you are right about that. There are serious differences. :) i am not an anihhilist. i agree. But... see it from another perspective.
Imagine you want to replicate Peripeteia, ok? you gonna use thick gauge wires for the motor power coil (that's the grinder) and finer gauge wire for the accelaration part. (HV coils) You should agree by now.
Image you want to eliminate the two different kind of coils so you want a SIGNLE COIL that combines HV acceleration and power creation in a delicate balance.
I think that's the original Adam's motor.
I hope i did not confuse you. Anyway, Thanes smart setup distinguises the accelaration part from the motor part. This achieved to better and more efficiently (i think) make the two different systems.
Of course, that is my oppinion. :D
Regards,
Baroutologos
I think there are several variations of this setup that may work. The key is to get it to self-run once then to duplicate. Thane has shown us it is not "magic" like so many other people have claimed. It is understanding the underlying principles of cause and effect which Thane has done so nicely shown in numerous videos. I do believe that "Mikes PMM" did self run with only a capacitor. The key was that he used a lot of turns of fine wire woven with his thicker drive wires. This is a lot like Thanes dual wire core approach. What Mike did not understand was that his fine wire was shorted somewhere and helped cause the effect. Most of Mikes circuit had very little to do with his motor self running and that is why it did not make sense to anyone.. It was one of those hidden "gotchas" that Mike did not see so when he tried to duplicate the motor it failed. Once the duplication failed Mike just disappeared since he knew that if he could not duplicate the motor the chance of anyone else duplicating was null. There are so many things that can go wrong such as having the wire short out in exactly the correct place for the effect to occur. In Thanes case it is more science rather than blind luck. Being science it can be explained and duplicated with success instead of being "magic". I think Thane is on the right track and it will be easy for others to duplicate once a few more "unknowns" are worked out. My guess is that Thane found another unknown that he has to work out in order to continue. At least now I am getting a handle on how it all comes together to work. Thanks to Thane.
baroutologos
I am in the process of mounting the magnets and seeing this thread i have been somewhat confused.
I am after at obtaining the most easiest way for producing the accelaration effect.
What magnet configuration is optimum for this? standard alternating NSNS?
I saw that recently Thane used NNSS setup. This initiates the phenomenon easier? What about a all N faces out? (like BEdini's FEG?)
Some advice here is welcomed.
Regards,
Baroutologos
Covey
I only wanted to state that my experience in what Thanes working on is limited but from what I understand it does sound extremely exciting. I find myself running each day to this forum to see if Thane has a new video or statements on his success.
It is a wonderful dream to make this world self sufficient in energy and take away power from the corruption that goes on because we are surviving on the Oils.
Just want to Thank you Mr. Heins for giving us real hope and making possibilities that says we are being held back from our true potential.
Brilliant Canadians which in the future might be Honoured as they should be:
Thane Heins for the Perepitea and a man Rick Simpson rediscovered the Cure for Cancer as well as many other maladies Curing Diabetes, All skin Cancers etc. just by ingesting his Oil. It is an amazing miraculous story that continues to grow more truth as each year goes by.
Covey WhiteGold
baroutologos
i know i have missed much of this Thread, but i notice something. Pls comment also.
Thane said that he is using standard 30 agw @ 150 ohms as HV coils.
From the last pictures of  the coils mounted on the toroid i noticed that this is NOT the case.
There sees to be coils with more or less those specs:
inside diameter:          25mm (or 2,5 cm)
coil height:                  65mm
estimated wire used:  24 awg or 22 but NOT 30 AGW
estimated coil diameter: 80mm
estimated wire layer thickness: 30mm
using the COil maestro software i estimated those also:
estimated wire resistance: 70 ohm
estimated coil weight:  3-4 pounds
see his post and view pictures. then take in consideration what i say.
http://www.overunity.com/index.php?topic=4047.4680
Any comments?
minde4000
Well coils can vary obviously according his different setups.  The question is what is magnet polarity?
