Thane Heins Perepiteia.
innovation_station
Quote from: rukiddingme on February 26, 2008, 11:08:06 PM
@ innovation_station,
In the last drawing, I'm not sure you need the two wheels in the center.
Can't you just use one wheel with one array of magnets?
if i understand you correctely you are correct in this set up as it is an ac setup if it were a dc setup it should be used as showen
on the cap video  thing i never did read the amparage of the cap but it came out of the pressure washer showen in my turbine video wich was a 110 vac 15 amp motor
as for tha tech in the vid    ever herd of a MOTORAIDER?   LOL
ISTEAM!!
rukiddingme
Let me clarify,
In the drawing, there are six wheels with magnets on them.
There is one wheel at each end.
There are also two sets of two wheels each between the end wheels.
These are what I am talking about.
Seems you only need one wheel with one set of magnets
for these interior wheels. All the magnets have two sides.
Wish you much laughter.
innovation_station
yes you are correct ....
i will change it and repost it fixed
yes i have been haveing my laughs   ;D
there is really no need for a center brush in an ac  setup  to improve the copper disc further we should look at TESLAS work with his fuel less generator  setup and ask the question why did he devide the disc into sections!?!?!?!?!?!
ist
fixed the pic
PulsedPower
@innovation station, Isn't a homopolar generator just a bit OT, FWIW there is no need to use copper rotors for a continous output homopolar generator, by using ferromagnetic rotors and filling as much of the air gaps with ferromagnetic material as possible the magnetic field can be strengthened giving a higher output voltage. The university of Texas's electomechanics department made 9 ferromagnetic rotor homopolar generators for a tokomak experiment also the Australian National University has a large ferromagnetic rotor homopolar generator.
innovation_station
yes this generator has 3 outputs
1st is Thanes magnetic coupling to the induction motor
2nd is the 2 cores between the third core wich is shorted
3rd is the hpg's
all with verry low backtorque
enough out of me this is THANES thred
l8r
william
food for thought
