Thane Heins Perepiteia.
aether22
BTW just got my cheapie 2nd hand bench grinder home, it's only 150W so it may burn up!
Or should i keep this one on the bench? (Yes, a sports joke)
Still worth a try, once I have proven the effect I will use a larger synchronous motor I have to run the generator by a belt and have the axle end of of the generator outputting to this one as effectively a detector, no physical connection.
Going to need to hunt down Thanes one again to see it's wattage, guess I will just need to reduce losses a bit which I will to with my laminated core. (and only one)
powerunlimited
Hi Thane
In the video one and two,the coil used what gauge of wire and how many turns.As i understand it the magnets are arranged n s n s,what happens if there all south or all north,do you still get the accelerating effect.I'm attempting to duplicate your set up i have the wheel, motor and variac waiting on more magnets and cups.I think your onto something very important!!
aether22
Thane mentioned to me that using 6 or so magnets is fine, would be interested to hear Thanes answer to your questions too.
OilBarren
Quote from: aether22 on February 28, 2008, 11:50:39 PM
IF I AM NOT MISTAKEN MINE IS 95 W?
OilBarren
Hi Thane
22, 26, 30 GUAGE THE TURNS VARIED FOR EACH COIL I MADE I AM NOT SURE WHICH GUAGE IT WAS - BUT MOST LIKELY 26 AND 75 OHMS WORTH.
I STOPPED COUNTING TURNS AFTER THE FIRST WEEK OF YEAR 1 - OF 7 YEARS OF TURNING.
I USED RESISTANCE AS MY PERSONAL GUAGE MY COILS RANGE FROM 75 OHMS TO 275 OHMS.
YES YOU DO (GET ACCELERATION) THE ONLY DIFFERENCE IS YOUR AC OUTPUT SINE WAVE WILL STAY ON ONE SIDE OF THE ZERO AXIS.
Thane
