Thane Heins Perepiteia.
OilBarren
Quote from: jacksatan on March 12, 2008, 06:54:17 PM
Quote from: gotoluc on March 12, 2008, 03:57:57 PM
Test seem to support Thane's earlier conclusion that the more turns the more is the output WITHOUT INCREASING THE PRIMAY INPUT POWER.
I'm confused (again - it seems to be happening often these days). Acording to your posting input power increased every all test scenario, ranging from a 30-50% increase, with the biggest increases in tests 3 and 4 - where there was actual measurable output... what could you be referencing when you say WITHOUT INCREASING THE PRIMAY INPUT POWER?
JACKSATAN, IF YOU REFER TO OUR STARTING POINT IN TEST # 1 ? WE START WITH A PRIMARY NO LOAD POWER DISSIPATION OF 4 WATTS. (LUC AND I ARE ENDEAVORING TO OPTIMIZE OUR PRIMARY PERFORMANCE I.E. LOWER CURRENT DRAW)
THEN THROUGH VARIOUS WIRE CONFIGURATIONS WE FINALLY END UP WITH AN END RESULT IN TEST # 5 (SUB TEST # 4) OF 2.39 WATTS THROUGH OUR LOAD.
PRIMARY I/P
1.80 VOLTS
2.65 AMPS
PF = 1
INPUT POWER = 4.77 WATTS
OUTPUT POWER = 2.39 WATTS @ 48.9 VOLTS
RECALL THAT WE STARTED AT 4 WATTS IN SO IN ESSENCE WE OBTAIN 2.39 WATTS OUT WITH ONLY 0.77 WATTS OF ADDITIONAL POWER IN
IN ALMOST EVERY CASE WE ARE SEEING AN  INCREASING POWER ACROSS  THE LOAD WHILE SIMULTANEOUSLY HAVING OUR INPUT POWER DECREASE ? IT SHOULD NOT DECREASE (THIS IS THE POINT) ? IT SHOULD INCREASE IN TANDEM WITH THE INCREASE IN SECONDARY POWER ACROSS THE LOAD.  (WE JUST THOUGHT THIS WOULD BE WORTH SHARING).
Thane
polarbreeze
Please find below (attached zip file) all the Toroid test Data done to date. It includes new test done on Toroid no. 3 which has 6 layers of winding per side = 5,800 turns each side, compare to Toroid no.2 with 4 layers per side = 4,000 turns each side.
Luc, it's not possible to interpret these results without knowing how the secondary coils were connected in each of the tests. They can be connected in various combinations, series or parallel or a combination, and in-phase or antiphase. It's essential to know that. Would you please post that info?
Thanks,
PB
polarbreeze
Quote from: OilBarren on March 12, 2008, 08:25:32 PM
...THEN THROUGH VARIOUS WIRE CONFIGURATIONS WE FINALLY END UP WITH AN END RESULT...
Again, Luc, "various wire configurations" doesn't provide the needed info. What exactly were the wire configurations?
Thanks,
PB
OilBarren
Quote from: polarbreeze on March 12, 2008, 08:31:41 PM
Thanks,
PB
I AM SORRY BUT THAT'S TOP SECRET INFORMATION WHICH CANNOT BE SHARED UNTIL LUC AND I CONTROL THE ENTIRE EARTH'S ENERGY SUPPLY - SORRY.
OR UNTIL YOU COME TO THE LAB AND SEE FOR YOURSELF?
Thane
ramset
PB you got another invite this is great    Chet
Thanks Grandma
