Thane Heins Perepiteia.
Charlie_V
He doesn't have the generator balanced yet.  I think the 90 watts difference is big step in the right direction.  I think Thane just didn't want to talk about input efficiency because he thought people might get turned off by it.  You have to start somewhere.
CRANKYpants
Quote from: Charlie_V on November 24, 2008, 09:10:18 PM
ONLY IGNORANT PEOPLE GET TURNED OFF BY IT, WELL INFORMED PEOPLE LOOK PAST IT SINCE IT IS IRRELEVANT AS LONG AS IT DOESN'T INCREASE.
T
supermuble
People are brain washed to show skepticism to new ideas. Those that are brain washed ridicule new ideas over and over and never once contribute to anything. Then when the final product works, these skeptics act like they believed it all along and even take credit for building the device in question! People..... WAKE THE HELL UP. Watch some David Icke videos... Don't believe what he says, just listen to his ideas. He can help you out of the "RUT" of negativity and skepticism.
Here is a David Icke video to watch
http://www.youtube.com/watch?v=MoXkTg-Uoz4
IT IS VERY SIMPLE. About 90% of the drag created in a motor is caused by Lenz's law. Remove that, and you have a motor that requires 90% less power to operate. NOW, You can produce any amount of energy that is conceivable without any power source whatsoever. It is indeed a Miracle.
CRANKYpants
QuoteIT IS VERY SIMPLE. About 90% of the drag created in a motor is caused by Lenz's law. Remove that, and you have a motor that requires 90% less power to operate. NOW, You can produce any amount of energy that is conceivable without any power source whatsoever. It is indeed a Miracle.
"All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident." Arthur Schopenhauer
hoptoad
Quote from: Charlie_V on November 24, 2008, 09:00:38 PM
By the way, using a HV coil is not the only way to do this - there is a simpler way.
Indeed there is a simpler way; Nali2001 and myself have both found in our own experiments, that it is unnecessary to have separate shorted high impedance coils to deliver a useful level of output through a low impedance coil. Nali2001 and myself have both achieved acceleration with low impedance coils, without resorting to a complete short circuit, using normal globes as loads. Nali2001 used solid cores in his setup, while I used hollow (solenoid) cores.
As for input being irrelevant, well it would be, if the input power cost nothing. But I don't get my electricity for nothing (or any other driving engine fuel), so as a consumer, it matters to me. If I spent 100 watts to get 1 watt out, it will matter very little to me how fast the generator / motor is turning, because I've just lost 99 watts for the pleasure of watching a rotor / motor spin whilst performing no other visibly useful mechanical or electrical work for that 99 watt loss.
Cheers
