Thane Heins Perepiteia.
Kator01
Hi forest,
I could not fully grasp your idea. Can you use this pic u-coil-fluxpath and edit the magnets in there ?
Have you a software for this ( corel or adobe ) ? or make a handdrawing ?
When I look at the fieldlines it seems to me that it resembles two magnets in a S-S or N-N configuration.
So when the magnet is sucked in ( coming from the left ) and the reed switches off in the middle-position you will then have the ractive EMF on the right coil-side in the same polarisation as on the left part where it was attracted in the first step.
But this can only occur if after switch off by the reed you instantly short the coil in order to get the opposite magnetic field. A open coil just will have a reactive-Voltage,see ?
@Laurent : You will need a a circuit which puts the coil under load ( 10 ohm ) or short it right after the reed opens.
                      Can you get what I propose ? You will then get an opposed magnetic field which accelaerates the
                      magnet a second time and then decays.
                      This is one of the reasons why accelleration occurs in thanes setup because hv-coil is shorted
                       during the process. It would however run better ( accoring to my understanding) if he would time the
                       shorting of the hv-coil ( I already posted this )
I really would like to discuss this further but by now I would ask Laurent to open a new thread on this.
@Laurent : ask stephan, to open a thread, I think if this traffic increases on this interesting setup of yours we owe
                      it  to thane to not use more space here on this.
                      Or we move it to one of the bedini-threads which exist already
Kator01
woopy
@all
as Mr Thane seems to apreciate is " vacation" in CALIFORNIA   ;D i profited from this  entract to present a  Perepiteia complementary possibility with the UCC
but  as i mentionned earlier i would not disturb the real aim of this thread
so i opened a dedicated thread
btw as somebody any news of Thane      i am really in big worry            where are my blue coils??     ;D ;D ;D ;D
Laurent
blisteringanomaly
yeah, kind curious where he is also. Supposed to be sending me my rotor sometime this week, getting anxious.
CRANKYpants
Quote from: blisteringanomaly on February 02, 2009, 05:49:55 PM
STILL ALIVE...!  :P
GOOD TRIP TO CA - SIGNED A DEAL.
BEING INTERVIEWED TUESDAY ON CBC RADIO TO BE BROADCAST WEDNESDAY.
WE ARE HAVING A MINI DRAGONS DEN HERE IN OTTAWA AND OUR COMAPNY IS 1 OF 3 OUT OF 47 CHOSEN TO PRESENT TO THE DRAGONS.
TORONTO STAR IS PREPARING FOR A "1 YEAR LATER" FOLLOW-UP ARTICLE.
PUT I_RONS' NEW ROTOR ROTOR ON THE CA PROTOTYPE (LEE VALLEY MAGNETS) AND GOT ACCELERATION WITH AS LITTLE AS 48 VOLTS TO THE MOTOR @ ABOUT 2500 - 3000 RPM.
PUT THE OTHER NEW ROTOR (75 LB PULLING WEIGHT MAGNETS) ON AND GOT 10 WATTS OF OUTPUT @ 1000 RPM OR 30 W AT 3000 RPM.
BENT THE MOTOR SHAFT TRYING TO HAMMER OFF A HOT ROTOR/DRIVE SHAFT AND HAD TO SEND OUT FOR A NEW MOTOR.
HAVING I_RON'S ROTOR SENT HERE W/ 75 LB-ER MAGNETS AND EXPECT TO GET ABOUT 50 - 60 WATTS FROM MY LATEST (LOW COGGING - LOW HYSTERISIS) COIL - CORE.
CHEERS
CHEAP- ASS-CRANKYpants  ;)
blisteringanomaly
awesome stuff thane! Read everything before you sign anything tho!
