Thane Heins Perepiteia.
Quote from: CRANKYpants on February 11, 2009, 07:03:03 AM
THANK YOU FOR NOTICING SKYWATCHER.
I BELIEVE THE ONLY WAY HUMANITY IS GOING TO SURVIVE IS IF WE REMOVE THE COMPETITION URGE IN ALL OF US AND LEARN TO WORK TOGETHER.
T
I agree 900%.
CRANKYpants
Quote from: broli on February 11, 2009, 07:28:40 AM
I agree 900%.
THANKS BROLI!  ;)
I REALLY DO SEE THIS COIL DESIGN AS A PHYSICAL MODEL FOR THE WORLD...
LENZ LAW = OUR HUMAN RESISTANCE TO CHANGE OR FEAR OF CHANGE
CORE RELUCTANCE = RELUCTANCE TO CHANGE IDEAS AND SEE OR EVEN TRY NEW THINGS
COERCIVE FORCE = ENERGY REQUIRED TO MAKE PEOPLE CHANGE THEIR MINDS - REMOVING PREJUDICES.
HYSTERISIS = THE ENERGY WASTED RESISTING NEW WAYS OF THINKING OR SEEING.
NOW IN OUR PEREPITEIA GENERATOR = (EVERYTHING YOU ONCE THOUGH WAS TRUE IS NOW FALSE)
SO WHEN WE GET EVERYTHING WORKING IN HARMONY = HV COIL AIDING ROTOR AND AIDING HC COIL AND HC COIL AIDING HV COIL THEN OUR EVENTUAL ENERGY GAIN IS 20,000% AND THAT IS JUST THE TIP OF THE ICEBURG.
WE EVEN USE WIRE RESISTANCE AND IMPEDANCE IN A POSITIVE WAY...
SO THIS WORK IS ALL MY PRAYERS IN PROGRESS.
CHEERS
T
Lol  ;D. The Perepiteia Bible. Will it be sold along side the Perepiteia?
sparks
    I-ron  sounds like a good machinist so he would probably be able to build a double output motor like below.  Instead of stressing mounts and such you tie down the stator with a counter-load.  It doubles your output.  The stator/auxillary rotor has to be balanced and the motor has to be a double shafted one.  The whole assembly is supported on pillow blocks and you need to add sliprings to the stator and a pulley.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
CRANKYpants
Quote from: sparks on February 11, 2009, 08:25:34 AM
YES I_RON SOUNDS LIKE A GOOD MACHINIST AND HE LOOKS LIKE ONE TOO ALL HANDSOME AND SUCH,
UNTIL YOU NOTICE HE ONLY HAS A THUMB REMAINING ON HIS RIGHT HAND...
WHAT DOES THAT TELL YOU?
TOO MUCH HABITUAL SELF INDUCED JACKING OF THE PRESSURE RELEASE NOZZEL - THAT'S WHAT!
I_still_RULE
