Thane Heins Perepiteia.
aether22
Quote from: OilBarren on March 16, 2008, 08:13:14 AM
IF ANYONE WANT TO KNOW HOW EASY IT IS TO REPLICATE THIS WITH THE CORRECT IDENTICAL COMPONENTS - CARL FALSNES RECREATED IT IN 1/2 A DAY.
Thane
Did he replicate the effect?
OilBarren
Quote from: aether22 on March 16, 2008, 10:33:55 PM
Thane
YES
OilBarren
Quote from: gyulasun on March 10, 2008, 10:55:30 AM
Hi Luc and Thane,
Thank you for the test results.  The data you measured indicates to me that the primary coil has got very low number of turns for your 60Hz mains voltage, the coil inductive reactance I think is very small:  at 2V AC input from the variac the 2A current is extremely high and I do think it oversaturates the core the primary is wound on.
If you are aware of this saturation and you designed it on purpose, than it is ok but for me it is an unwanted situation in case of electric transformers in general.  rgds,  Gyula
THE IDEA IS TO OPERATE THE PRIMARY AS NEAR SATURATION AS POSSIBLE - TO KEEP PRIMARY RELUCTANCE HIGH OR AT LEAST HIGHER THAN THE SECONDARY SO SECONDARY INDUCED MMF?S CANNOT NOT COUPLE BACK THROUGH THE PRIMARY CAUSE IT TO DRAW ADDITIONAL CURRENT FROM THE SOURCE.
Thane
hydrocontrol
Quote from: OilBarren on March 17, 2008, 06:21:49 AM
Thane
YES
Half a day to replicate with the correct parts. This sounds reasonable and I am sure there are many builders that would like to replicate..  Is there a condensed guide (perhaps PDF) that can be used to replicate this project instead of reading 64 pages of questionable and confusing banter ?
Thanks,
TomG
aether22
Quote from: aether22 on March 16, 2008, 10:14:15 PM
Actually make that $70 right now...
Note: If need be I could find more money, as much as say $130 immediately, and I would choose for it to be sent now rather than later.
Oh, and apparently the best way is by Canada Post  'Expresspost International' if not unreasonable.
