Any electrical engineers out there??
Started by Super God, February 04, 2008, 05:58:14 PM
pese
if you will use fets use the type that i give you by mail  1800volts.
the fet-switches that you shown he DONT WORK !
Give attention this are fet swiches for 110 and 230volt (ac) application.
this are "optocopler" that say:
the ISOLATION Votage between input and output can be up to 100kV
YOU CANT SWITCH this Tension (voltage).
Its wvry old "goodknow" technology .
Pese
To switch hi Kvolts .
use rotary contct wit air-gap
gyulasun
Quote from: pese on February 09, 2008, 09:16:19 AM
Pese
Hi Pese,
I fully understand you offer MOSFETs of 1800V drain source voltage ratings for sale, this is OK.
With due respect indeed, but I do not think it is ok you say the MTP1N100 MOSFET types (that are included in series in the 8kV switch) do not work, when they are actually do.  They have 1000V drain source voltage ratings and the parallel MOVs with their 920V ratings should protect them in case the 1000V limit is approached.
Finally I do not understand at all where is the 100kV opto coupler mentioned or applied in this paper???
( http://bromine.cchem.berkeley.edu/grppub/frbm2.pdf  )  Please refer to text where you found it? Or did you mistyped it?
Gyula
sm0ky2
If yur looking for a cheap solution, find you one of these bucket-men, that climb the utility poles outside, and get a switch from him,
the ones they put on the transformers before a residential drop should be perfect for what you need.
you can operate it with a 5v IC chip and set whatever frequency you want on the thing, up to some limit which is ungodly higher than 120hz,  these switches handle a 3-phase signal at a MUCH faster rate.
Super God
Maybe I could use the distributor from a car?  The source is gonna be a capacitor bank (big) and when the distributor closes the circuit the capacitor will discharge through a spark gap.
>9000
pese
Quote from: gyulasun on February 09, 2008, 10:55:51 AM
Pese
Hi Pese,
Gyula
Soory for wast time.
this you can make yourself. !!
Constructing an CASCADE with 10 pcs of 1000 volt transistors.
(20 pcs 500volt transistors) .
all collector to the emitter of next transistor.
ech transistor will be driven from an smal coupled windings (secondaries 1 to 10). the connect emitter an base trom each single transitor.
this arrangement is drive from an primary that is connected to this DRIVER Transformer..
each winding must be good isolated from ech others.
THIS sort of CIRCUIT can only PULSING  the transistor arrangement for short time ON.
That will be OK for the use that you need.
Gustav Pese
