12V 60A car battery , maybe dead?
Started by gezgin, February 05, 2008, 04:01:31 AM
bourne
@ Groundloop
I Like it!  :)
I will defiantly give this a try when I get a chance.
Seems very simple.
@ GezGin
Have you tried it yet? Hows your sickly battery doing? :)
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
gezgin
Hi Groundloop , i have build your circuit (with two coil) short time because Bux80,bd139  very hot .(i measured frequency ~100Hz).
and building new design with 4093 osc ~1Khz
but with this circuit needs heat sink output power diods (DSI20-12A) .battery shows 11.1 volts ,with small increasing.
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
Groundloop
@gezgin,
You must have a good heat sink on the power transistor. Please remove the BD139, it is NOT needed
for this circuit and will just make the amplification WAY to high. Can you provide a data sheet (pdf) for
the output diodes you are using?
Groundloop.
Groundloop
@gezgin,
the output diodes you are using? Also, where is the third coil L3? This coil is there so that you will NOT
couple the input direct to the output through the diode bridge. If you build the circuit as I described in my
drawing then it will work OK. The input voltage must be around 9 Volt, not 15 as you use. If the oscillator
does not run then invert the wires on the trigger side.
Groundloop.
gezgin
Sorry diod is DSEI120-12A
http://pdf1.alldatasheet.com/datasheet-pdf/view/212503/IXYS/DSEI20-12A.html
other : FEP16GT
http://www.fairchildsemi.com/pf/FE/FEP16GT.html
I used heat sink but i didnt find 500 Ohm 3.5Watt resistor(adjustable)
I found 470 Ohm/5Watt power resistor.
Groundloop, what is the time for desulphating with your circuit?
in  Japanes site talking about 4-6 week ,10KHz
Unfortunately my battery voltage drop every day 9-8-7.. maybe new one, good quality need
here scope photo (with 4093 osc)
