12V 60A car battery , maybe dead?
Started by gezgin, February 05, 2008, 04:01:31 AM
Groundloop
Quote from: Mars67 on February 04, 2015, 12:38:54 AM
Thanks GL
I will test it this evening when I get home. When I had the circuit built on the bread board it did not run with the L1 wires reversed but will test it anyway on the circuit as built.
Could the way the coils were wound have anything to do with it?
Mars67,
Your coil is very good and professorial made so I do not think there is any problems there.
You should see if you can afford a o-scope. Even a used and older o-scope will do fine for
basic electronics like this. A o-scope will show you the waveforms in the circuit.
GL.
Mars67
I agree. You can't fix what you can't measure. What Frequency range would be adequate? 10Mhz?
Groundloop
Quote from: Mars67 on February 04, 2015, 07:57:21 AM
Mars67,
Any o-scope will be better than none. I really can't recommend a type for you, but
if money is a concern then look at eBay and other web sites. There is also many
"made in China" digital o-scopes that can do a OK job at a reasonable prize.
Did you perform the swap L1 wire ends test?
GL.
gotoluc
MarkE
Quote from: gotoluc on February 04, 2015, 04:01:23 PM
Best scope I've used for the money. $148. with delivery
http://www.ebay.com/itm/121446312238
Luc
I recommend spending the extra $20. - $25. and getting the newer model 6052BE with higher bandwidth, faster sample rate, and deeper memory:
http://www.ebay.com/itm/Hantek-PC-Based-USB-Digital-Storage-Oscilloscope-6052BE-50Mhz-Bandwidth-/221271002722?pt=BI_Oscilloscopes&hash=item3384c78e62
