12V 60A car battery , maybe dead?
Started by gezgin, February 05, 2008, 04:01:31 AM
Palic
Palic
@Groundloop
Can you please tell me how should I wind all three coils at once? ???
Should they be wound by hand, randomly...just taking care that
all three wires are wound at once?
Or they must be wound in some special way?
I have ultrafast diodes BYV79E-200, they are 12A, less than 30nS,but
only 200V -is this enough, or should I order the 500V diodes.
Oh yes, is the answer is that I should order the 500V diodes, I have
another question..
Can I connect serialy 2 diodes of 200V ,and get 400V diodes without loosing
the less than 30nS parameter?
I have 4 batteries of 12V 180Ah each, they are in very bad shape
Before may 1 I must try something to do with them to get back the
capacity, or spend about 800EUR for the new ones. :'(
Please help
Thank you Palic
Groundloop
@Palic,
Take a empty 1/2 litre Cola plastic bottle. Wind all three coils at the same time around the bottle.
Secure with tape when done. Then cut away excess plastic. It will take you maximum 10 minutes.
BYV79E-200 is OK. No need to connect diodes in series. 200 V is OK.
Just do NOT run the circuit without a battery connected on the output.
Groundloop.
Palic
Thank you Grounloop for your quick reply.
Today I managed to get the wire,and they are:
1,1 mm - 1,1 kg witch I mesured 145meters,and 2,7kg of 1,05mm wire witch will
be the other two wires when split in two parts.
As I calculated I will need about 75meters of wire for just one wire of the
trifilar winding when using diameter of 100mm.
I will present the calculation:
ID 100mm, OD 120mm so the middle is 110mm
110mm * PI =0.346 meters for one circle of winding
as I need 600 circles it will be 207meters of wire
or for trifilar winding it will be 3 wires of  69meters,
and the windings will not be perfect so I guess it will
be something like 3 wires of 75 to 80 meters.
If I am wrong please correct me.  :-[
Thank you
  Palic
Groundloop
@Palic,
Yes you got it right. It is NOT that critical and the margin for error is big.
Groundloop.
