The secret of a working perpetual motion gravity powered device
Started by gurangax, February 28, 2008, 12:33:16 AM
hansvonlieven
Quote from: gurangax on March 01, 2008, 05:05:11 AM
Quote from: hansvonlieven on February 29, 2008, 08:29:27 PM
Quote from: gurangax on February 29, 2008, 05:13:56 AM
Quote from: hansvonlieven on February 29, 2008, 12:08:36 AM
Quote from: gurangax on February 28, 2008, 11:57:49 PM
Greetings to all.
Thanks to some emails now I can see things clearer. I'm not concerned anymore about the prize money. It means nothing. But like I told you guys in the previous post I don't like to give the answer directly. You must think before I give you my answer.
You have a lot to learn my boy !
Hans von Lieven
Thank you. Can you teach me?
http://keelytech.com
Hans von Lieven
hi
the link is dead, but I think I've been there before. Sorry for bothering you
Something must have gone wrong your end, the link is very much alive
Hans
aleks
Hans von Lieven
Thanks sounds interesting. So, was Keely able to put a steel tube into self-sustaining resonance that was emanating acoustic waves and at the same time disintegrating that tube? Should be working like a tsunami wave that builds out of nowhere in the ocean. As you know, this wave is self-sustaining. But what's more important, it is sustained by smaller RANDOM waves that surround it (ocean is never calm). Probably, random (heat) movement of particles can be also used to support the self-sustaining resonance of the tube. Sounds like a break-through.
I'm as a bit of self-educated acoustician myself can envision that this tube is able to tap energy from random mechanical high-frequency oscillations into lower frequency oscillations - probably in a constant fashion. It is actually working as an acoustic frequency shifter (reduction gear would be a mechanical example) with a multi-octave arrangement. Even though, heat movement of atoms is considered to be random (white noise) due to geometrical structure of the matter it may exhibit acoustical modes that can be shifted to a lower octave. Beside that the white noise itself can be at first band-passed in a resonator and then fed into a frequency-shifter. Then shifted to even lower octave, etc. The heat movement of atoms is ever-running, and so the sound-generation can be made continuous.
On the other hand if that feat is possible, what is matter if not acoustic waves?
hansvonlieven
Good man aleks,
Keep thinking along those lines. Keely was miles ahead of us as far as acoustics are concerned. Good luck with your research
Hans von Lieven
gurangax
Sorry guys
I don't have internet connection at home and I go to the town to have it. I read a few of chas campbell snooker wheel thread and since it will take quite some time for me to understand all of your points there, I'll just copy them and read it after I go back home. I have not seen the video yet and I am downloading it at the moment. In the mean time, If you guys found out how to solve my wheel problem don't hesistate to send it here.
-regards-
p.s I'm still unfinished writing my supposed to work explanation.
gurangax
Quote from: P_M on March 01, 2008, 08:44:28 AM
QuoteIf you have the time and are interested, It will be a good thing if you will model an animation of my supposed to work device after I gave the solution. Many thanks
it always develops something other me interestedly in the area of energy.
I already have a model this works, so I do not have to look any more for the solution.
you do not know either whether your solution works, since you have not built any model still.
nevertheless good turn out well.
Well I'm curious to. What is the name of your perpetual motion device. And have you guys disccussed it here yet. also are you willing to send me the video of it?
thanks
