Potassium Alum Pyramid (growing crystals)
Started by Drannom, March 05, 2008, 01:59:27 AM
Drannom
Quote from: jeanna on October 15, 2008, 08:58:12 PM
I have a friend who made a movie of a slowmo vortex that happens in water sitting under a pyramid. He is promising a cd but not yet, so I cannot show you. But maybe it would work to make a posterpaper pyramid to put over it.
It would save electricity.
I am just not ready to do it yet - lab is full still.
jeanna
Hello, it would be very interesting to reproduce this experiment or to see that video
i can try it with a potassium alum pyramid over a glass of water with sea salts in it and with some pepper at the surface, and watch if there is some vortex taking place there, then it would be a super wonderfull youtube video to confirm the energy of a potassium alum pyramid
i have seen a picture somewhere on the net of a metallic pyramid with a vortex over it, they were using a Tesla coil and the voltage cross the pyramid from the bottom to the top, and they have get a picture of an electric vortex over the pyramid
with the Super Light theory it is become easier to understand what's cooking when you place a pyramid anywhere, not only at the surface of the earth and not only with the earth energy
i mean that Super Light come from all around us , from all the black holes of our universe, so Super Light rays are hitting the pyramid by all directions in the same time, the shape of the pyramid act as a sort of diode in the etheric field, the pyramide create a directionnal flow in the etheric field, and the flowing result is a rectified Superlight from the bottom to the top of the pyramid, and vice versa
there must be the same effect over the pyramid, so 2 vortexes
Potassium alum pyramid catch more super light than a chaostic object, (all crystals do this) the molecular frequency of the potassium alum molecule tune the Superlight, the pyramid shape create a vortex over the pyramid, and this vortex create green and blue astral lights over the pyramid
And superlight pass through a pyramid like ordinary light, so it is only a thiny part of the superlight that is transform in astral light, corresponding with the molecular frequency of an potassium alum molecule
there are much more to say, while a potassium alum pyramid is growing it produce heat, and this heat creat a flow of liquid (convection), the heated water going up by the top of the pyramid, i never notice if this flow is rotating like a vortex
so thank you Jeanna !  2 more experiment to do
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
jeanna
You are welcome Drannom,
I look forward to hearing the results you get.
My friend is away at work for a few more days. I will ask him for the details of spin again when he returns. I did already, but at the time it was from interested curiosity and I do not remember how fast the vortex moved. - except that it was slow and needed to be filmed in a  stop motion sort of way.
Actually, however, if it is a pyramid that is making the vortex that moves the water, perhaps it will be the exactly right speed to create another one in the solution!
I am always hopeful for easy and excellent results.
Thank you again for sharing your techniques with us. (I love the potential that is in a pyramid!)
jeanna
nievesoliveras
Hi!
@drannom
I saw your videos and read your thread here on the forum. A resumen would be:
Everything you need to grow a crystal:
- saturated solution
- heat (energy) source (a lamp)
- seed crystal (a tiny crystal on a glass plate)
- Feeding bottle with over saturated alum solution at the top
-Heat lamps to stimulate the alum to be dissolved, causing
  gravity to pull some of it out of the bottle.
-A little rotor to cause the solution in the tank to "vortex", in order to
  feed dissolved alum to the alum crystal on the bottom evenly on all sides.
-A foam disk shadow zone keeps the seed crystal and the growing pyramid crystal cooler
than the rest of the solution, allowing the alum to condense and bond to the crystal.
1. A piece of glass with 1-2mm hole at the center
2. I use glass (crystal generator) and (ceramic and chrome for the container).  It can be anything else except wood, rubber or metal and the saturated solution must not be in contact with little bubbles of air at the surface of any object or inside the object because it will start crystallizing by contact, creating an excess of alum (absorbing water) and explode in microscopic little crystals. Little bubbles alone, is not a problem because there is no absorption.
3. There is only one way to adjust the saturation of the solution. It is by dissolving it each day and add some more alum or some more water and try again.
A scientific technique measures the quantity of water and the quantity of alum as well as many others factors that influence the crystallization, like air atmospheric pressure for example. Another example is that moving water will dissolve more alum than a static dormant water. The reason is that alum in its dissolved state, is attracted by the gravity at the lower part of the container.
4. You need 3 or 4 flat top pyramids to successfully create a crystal generator, you will fail until you get experience, and knowledge.
5. Tape one flat top pyramid crystal to the underside of the hole in the little piece of glass. The flat top must be larger than the glass hole. The flat top will adjust the crystal network perfectly with the surface of the glass. The hole must be facing up and filled with a needle to push out the air inside the hole.
Maybe I made some mistakes, but that is what I understood of the tecnique.
Jesus
Drannom
Hello Jesus, you are a genious ! you have learned almost perfectly what i do
i just want to complete your post
the gravity attract most of the potassium alum dissolved at the bottom of any container, with the vortex propeller we homogenize the solution, then there will be no over saturation at the bottom
for the seed germination, the gravity will do some pressure at the bottom, and more the concentration increase more are the chance to get a micro-burst, each micro-burst will give a crystal, so in the seed germination we need to get the saturation increase slowly with a slowly cooling method
if it is not working then we have to increase or decrease the saturation and try again, and yes the atmospheric pressure is a parametre, and there are too much parametre, we have to let down the scientific method and make some manual calibration of the solution
if we get a slowly cooling then the micro-burst will be stronger, with a micro-burst you can get together 2 molecules, or 3 molecules, or 4 molecules, or more
if 2 molecules cristallized in a micro-burst then they fall down at the bottom of the container and keep going cristallizing with other molecules, it will be the normal form of potassium alum, kind of hexagonal shape
if 3 molecules cristallized in a micro-burst, then it will look like a chair with only 3 legs, the 3 molecules fall down and keep going cristallizing, it will be possibly a pyramid or not, cause the forth leg can cristallize just before the structure touch the bottom of the container
if 4 molecule cristallized in a micro burst, then you get a pyramid
if more than 4 cristallized, then the solution has been cool to fast, or the solution is too concentrate, with 8 you get an octahedron ! very rare
if you get sort of snow on all the bottom's surface, then cooling too fast or solution too concentrate
Jesus you have catch the crystal generator too ! very good
to grow a pyramid with a crystal generator you have to place the crystal generator (or a big seed) in a solution of water and potassium alum just saturated a little bit and a little hot, so the crystal will melt a little bit before growing , again the most difficult part is to calibrate the solution, i do this simply, i use a poor solution with alum in it at room temperature, and i add the part i wish to dissolve, and then when cooling the same part will come back
so, i put the crystal generator or a big seed in the Cristallarium, then it is dissolve a little bit the time of the first cooling (1 hour max), and will begin to cristallize then, after this we have to inject alum from a hot saturated solution (30 celsius) to the Cristallarium (20 celsius), and the difference in those temperature give the right concentration
you can inject with a feeding bottle or a circulating system more complex
the lamp under the foam disk is for 2 purpose, first it is for get the bottom as hot as the top of the solution, even if you use a propeller there will be always a difference between the top and the bottom temperature, second it prevent bad crystal to appear everywhere, cause the glass or ceramique will transmit some cool, sort of lack in infra red rays, in the seed method the glass will give the micro-burst as the cold enter the solution by the bottom, and third the lamp can control the speed of the growing crystal
Hello Jeanna, i have not try the experiment yet, i promise you to try it first tomorrow morning, and i will make a video in slow motion, last year i have put a big pyramid on a floting foam, the pyramid was always moving slowly, i will do it again in my basement to avoid any vibration, my theory is the superlight field is not constant, as the black hole rise and set like a sun in the sky
the center of our galaxy is at aquarius (i think) so it is like a sun rise and a sun set, in fact all planets in our solar system change the field of the superlight
good night
nievesoliveras
Hi!
Thank you drannom!!!
You are a great teacher!!!
Jesus
