Single AA battery to light WHITE LED for long-long time
Started by zon, March 05, 2008, 05:18:40 AM
innovation_station
Quote from: -[marco]- on March 16, 2008, 04:21:54 PM
Quote from: Feynman on March 14, 2008, 05:20:17 PM
Yeah, I agree.  We don't know if it's OU .   But strange enough to warrent ... EXPERIMENTS!!!   :D  8) ;)
Hi
I have played with many of these types of devices a couple of years ago and as they are presented here they are not OU devices.
But they can be.
For this to be, you only need to put in a verry small spark gap and make sure the voltage is sufficient.
Im not talking about millimeters sparkgap but rather one hunderth of a millimeter.
Much like when you use two pencils and the tips are almost touching each other.
The miniature spark will imediatly push up circuit performance.
It is in the disruptive discharge.
You also need a couple more diodes of the ceramic HV model to redirect energy back into the battery/capacitor.
A combination of capacitor / neon bulb will also work verry well.
In that case it runs on bemf and the voltage produced is many times higher as the pulsing voltage.
No need to use galvanic coupling, it can be done wit a simple primary coil only.
The capacitor builds up a charge ,and this charge will keep building up untill the voltage has reached a certain value and it will discharge itself thrue the neon bulb.
Mechanical switching works best.
M.
@ marco   awsome!!
:) ;) ;D
ist
Feynman
I think the spark gap should go between the output coil and a destination capacitor.  As marco says, it will have to be measured in micrometers so I'm still trying to figure out a good way to do that.
Also , had a drive crash so I am delayed a day or two.  But I will return.   ;D
amigo
I knew I should've bought a microscope long time ago...now that this micro-spark gap is needed it would've come handy. Though I think we need a metallurgical microscope instead of biological one (which I was looking to buy).
What kind of material should the spark gap be made from and should it be encased in an evacuated capsule?
Feynman, sorry to hear about the drive crash, I hope you didn't lose any important data...
zon
@all
My friend told me that he will go to my place next month.
I try a lot of type of circuit "led" but still not get "energy".
Some time the battery not drain for while and go down again.
zon
Feynman
Thanks amigo ; it's fine data was backed up .  :)
Just need to reinstall things.
