Shake-em-up flashlight generator
Started by Formula1, March 07, 2008, 03:16:44 PM
nightlife
That is pretty much the same concept I had in another thread I started. One difference I see is that you are not utilizing the back EMF wich is actually a lot of power you are throwing away.
Formula1
Quote from: nightlife on March 07, 2008, 05:51:33 PM
I know exactly what you mean!
It could definitly be harnessed... I didn't even think of that...
I was going to make it (The images are pictures I took eith my digicam)
-But somethings stopping me... so I'm posting it up so that other people can make it for me...
hell, I'd give up the patent to get this thing made...
-But I'd rather use the patent for publicity for other things...
--But for some reason I get a bad feeling when I say that....
nightlife
I am getting some unbelievable results and I can't wait to get it finished.
Think about what you have and go back and watch the wind belt video posted in "nightlifes wacked out ideas". I will be adding to that thread later tonight and I think you will be very impressed with what I add to it.
nightlife
Formula1 I just bought one of those lights. It is a Super Power forever flash light. It says to shake for one minute and you get up to thirty minutes of light.
I shook it for one minute and I tested the leads to the LED, it was 3.25volts at .18 amps. I shook it again for two minutes and I got the same results.
This one has two coils, two rectifiers, I think that?s what they are and it has a capacitor. It also has a rather large neo magnet that is about 1X2 inches. The cylinder is about 1.5X8 inches and the coils are about 3.5 inches long and just fit in to the cylinder. The coils are in the middle with one lead from each going to one side on the board and the other leads going to the other side.
The wind belt is said to produce 4.5 volts with a much smaller magnet as well as much smaller coils. With the wind belt, only part of the magnet goes inside the coil but the magnet is much more vibrant.
It would take 2048 of these flashlight set ups to produce 130volts at 10amps. I do not know how many amps the wind belt puts out at 4.5 volts and I cant seem to find any specs on it. I will try and contact someone from that company to see what I can find out. I will also see if I can buy one and have them ship it to me. It may be impossible do to them still waiting on their patent to clear but I will still try.
But based on what I have seen, the wind belt is much more efficient then the flashlight and I believe it has to do with it's vibrancy. I will try and do some testing with the flashlight to see if I can get better results by splitting the coils and vibrating the magnet in between them. I am thinking that do to the larger magnets and the larger coils, I should get much better results then the wind belt claims it does.
One thing that I am not sure of is if the circuitry is going to handle any more then it may be rated for or if it will just max out at what it is rated for and I may not get any better results with using their circuitry.
I will keep you posted with what I find.
