Amazing welding machine !
Started by hartiberlin, March 11, 2008, 11:20:14 PM
helmut
His Wire is direct connectet to the Housesupply.
So he can take about 50 Amps without activate the linebreaker.
The welding rod looks like 1,5mm
helmut
retrod
Quote from: rensseak on March 12, 2008, 01:46:09 PM
You want to order? look here:
http://www.sulit.com.ph/index.php/view+classifieds/id/195962/smallest+welding+machine
Found an actual link to their website
http://www.welding-invention.125mb.com.2net.us/index.html
Far as I can see it, (the welder) is an aluminum block with a handle on it and two terminals. The operator is simply not grounded to damp/moist earth or the ground rod, thus keeping him alive. Does anyone see anything different? The high current really does a number on the rod, it almost explodes.
RD
retrod
Quote from: hartiberlin on March 12, 2008, 08:25:37 AM
Here are 2 more videos of this amazing welding device...
http://de.youtube.com/user/lmanalili
How does it work ?
It seems they just use only one wire from the grid and maybe the device is
just a special coil ?
But why doesn?t the guy get electrocuted when he is holding it in the water ?
Is there no current flowing through his body to earth then ?
Very strange...
Yes, I see it the same way. The power is connected directly to the mains and is bypassing what looks to be a fuse. I surmise the device is nothing more then an aluminum block with terminals on it. For example, here in the U.S. we have 110volts AC at a typical wall outlet. I can strip a line cord with both ends exposed and touch the hot side without getting a shock as long as I do not ground out to anything and complete the circuit. This demo must be conducted on bone dry soil that is not a conductor. This type of hype and demo for $$ is the worst kind of evil I have seen on the internet, they cannot be so stupid to not know how easy it would be to be killed.
RD
MeggerMan
Here's an idea, behind that big door is a full blown welding machine clamped to the metal he is welding with the otherÃ,  connection end connected to the junction box on the wall of the building.
The ali block is just a solid conductor, no potential drop, hence no danger of electrocution.
Any sensible person would wear a welding mask.
Yahoo and hotmail addresses, probably a free hosting webpage loaded with popups and adverts.
It stinks of scam to me.
Rob
