Charge Battery From Capasitor.
Started by slayer007, March 12, 2008, 04:07:50 PM
slayer007
Its from a pulse motor I was working on.
It has four coils triple wound.The four coils run it then I get power back from the other two wires in the coil plus the back emf from them to.
Just one of the coils can fill up the capasitor in about a min.
Getting a lot of power out of it just didnt know how to discharge it back ito the battery.
O its all so turning a car altonator when its running.But the altonators bad have to get another one.
zerotensor
Quote from: slayer007 on March 12, 2008, 09:04:22 PM
The capasitor I am using is 300v not 350v its a 4400 mfd
I have a few I could try the other two are 200v at 220uf Then 400v 120uf
4400 uF seems like way more than you would need for this application.  I hope that you have the terminals shorted with a wire. It would probably be wise to do your testing with the smaller cap, which will still pack a pretty hefty punch.
Groundloop
@slayer007,
4400 uF will fry your SCR in a short time! Use your 120uF 400 volt capacitor.
Also, be carefull NOT to touch the capacitor with your fingers when the circuit runs AND after the
circuit is shut off. The capacitor WILL hold its charge for a long time. Normally one solder a high Ohm
resistor over the capacitor leads to discharge the capacitor when not in use. In this case we do not!
The reason is that this waste energy and I guess that you are aiming for free energy. So in your case it
is best (after switch off) to discharge the capacitor with a 10K resistor manually before you handle
the circuit. Be safe.
Groundloop.
zerotensor
Quote from: slayer007 on March 12, 2008, 09:17:44 PM
This changes things a bit.  I'm not sure that Groundloop's circuit can tolerate this kind of input.  You might want to study John Bedini's circuits for some ideas on how to do battery charging with a pulse motor.  Perhaps you could just replace the capacitor with the battery directly.
slayer007
Thanks I will give that a try.
I ordered them neons off ebay and the tic106d allso.
The rest I should be able to get at radioshack.
So hopefully it should be done by next week.
I was thinking it might be to much power to But I could allso make one for each coil.
That way I could charge Five batterys off one lol.
Thanks agine. ;D
