Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
0 Members and 50 Guests are viewing this topic.
Grumpy
Quote from: Peterae on September 02, 2008, 05:20:16 PM
@ Grumpy
Yer but does it work, I take it from your in detailed explanation you have built it and got it working and have now worked out how it works?
I have not built the tetrahedral thing due to the required arrangement and pulse requirements.   I've built some other things and done a few experiments.  It's all related.  The foundation of what I just wrote is in Wilbert Smith's book "The New Science" - which is posted free online - Google it.   Others have confirmed various aspects of this as well.  These principles are also supported by the works and writing of Tesla, Eric Dollard, and others.
If you are asking if the tetrahedral arrangement will work or not - of course it works.  He did not post it for his health.
There are several ways to achieve the same results or others depending on what you want.  What I just posted is an outline for how the fields interact with each other.
        -Frank Edwards
Grumpy
By the way, if anyone wants the "motherload of OU" straight out of the gate with their first build - then this field isn't for you.
        -Frank Edwards
sparks
   @Grumpy
       The tempic field can be thought of as a bunch of clouds with different amounts of watervapor content.  Something like your avatar. :)  This is what would fill space dimensions.  The relative density borders then create charge which is an area or surface tension and relates to the square of the vector under question.  This charge surface then envelopes a volume which creates the magnetic field whose vector examination changes as a cube.  The watervapor is potential energy or potential for change or potential time.  Mass with all it's inertness (full of not changing) is pretty much antitime.  The only recourse man has is to manipulate mass that happens to be in his time density field to effect a flow from the tempic field.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Peterae
All these theories are great but i am yet to see any of them produce a working OU Device.
I am a builder and have built many devices over the last couple of years from instructions posted by people that come and go.
I will give this a go as the description is fairly good and easy to cnstruct, infact it shouldnt take more than a couple of weeks to get this up and running.
I see spider building and i have seen lots of theories but has anyone completed a build in the 4-5 months this has been posted.
I dont understand that Grumpy is so convinced this works and has not built one due to the pulse requirements?
I was a micro electronic design engineer and i would say that is not the way to go with this, the logic behind the pulses is straight forward and can be done with 5 logic chips, although i will opt for adjustable phase and pulse width which means i will need 9 logic chips to give me 10nS pulse switching.
Peter
Spider
Quote from: Grumpy on September 02, 2008, 06:12:15 PM
@Grumpy,
Can you elaborate on that?
Greetings Spider.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
