Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
0 Members and 20 Guests are viewing this topic.
Grumpy
Quote from: poynt99 on September 16, 2008, 08:40:37 PM
ic, well that explains a lot.
it's interesting how it's usually only those that feel they are elite somehow, and yet have produced nil results themselves that pipe up.
there are those that do appreciate the work that's gone into the document. not all are so negative, short-sighted, and knee-jerkish in their reactions. some may even be those that receive your kingly praise.
the thread's all yours grumpy
You missed my poynt.  I was trying to coax you into building the device rather than discussing how it works.
Nil results?  I've had and posted many results - most dispelling the myths surrounding radiant electricity - such as the "green arc".  I also showed that a compass will align to a static electric field as well as a magnetic field.
I have no results with this device because I'm not trying to build it.  Maybe I should.
Spherics handed to this forum on a "silver platter" and the response has been rather "ungrateful" - with the exception of a couple of people building.
Let's see now.  Four coils alike, yada yada, pulse three by phase and fourth with each of the three.  Only 300v?  NMR reference puts you in the MHZ range...doopty do...
So you could probably use something like a ring counter or Johnson counter, run the top coil off the clock and the rest off the counter.  Use counter output to trigger avalanche mode transistors or mosfets with delay line to set duration of the pulse.  Find Earl's ratrace controller in the Earl's Corner thread - this circuit has adjustment of the pulses - delay and width.  Google the avalanche stuff.  Google the hv power supply.
Anyone see why this approach will not work?
        -Frank Edwards
Grumpy
Link to Earl's Corner:
http://www.overunity.com/index.php/topic,2996.msg43797.html#msg43797
He has many ideas for pulse generation in this thread - time to try them.
(Of course a PIC is an alternative to logic IC's.)
        -Frank Edwards
otto
Mannix
Quote from: Grumpy on September 16, 2008, 11:50:01 PM
Grumpy,
That thread is off limits to most people here
Otto good work! ..I hope that you can make it clear enough for others to follow
otto
Hello all,
@Mannix
thanks. I learned here that photos, videos, pdfs are a must. No problem.
As Im not jet on the "end point" of my work it will take a time to finish my work. I dont care how long it will take but this "journey" is the best I ever made!!!
Otto
