Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
Grumpy
I have an old book on microfiche - real pain in the arse to read - Titled: "Techniques of Shaping High-Voltage Nanosecond Pulses", by Vorobev,G. A. ; Mesyats,G. A
In this they discuss how you can send a pulse through a spark gap (or multiple gaps) to decrease the fall time (or was it rise time?  maybe it was both? - web source John Pasley says "rise time").  They also used adjascent gaps for UV enhancement of the switching time of the main gap (think he called this a "spark relay").  UV lamps for reptiles may also work, and I'll be trying this along with a brush discharge from a Tesla Disruptive Discharge coil as well, when I have time.  Basically just screwing around trying to get vacuum gap performance without the vacuum.  Hmm - could setup a quenched gap sideways so that each gap UV's the one next to it.
I suppose, when it comes down to it, we need to look at the "entire circuit" when dealing with this sort of "thing".  From this perspective, SS is slow, tubes are faster, and SM was correct.
        -Frank Edwards
MarkSnoswell
*if* you wanted really fast pulses you "spark" through water... any you get well down into the picosecond range from memory... but you just dont have to go there, a fast mosfet switch is all you need these days -- easy if your switching under 600V -- it gets a bit trickier up to 1.2 Kv as the parts get more expensive. For the higher voltages - if you really want them - you should just use valves. Valves are cheap, easy and fast for higher voltages -- the current capacity is not a problem at all.
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
gn0stik
Quote from: -[marco]- on May 15, 2008, 01:25:17 PM
Take a close look at the CTC-5 chasiss :)
Nice find marco. I think I can even see a toroid in the middle there.
duff
Quote from: eldarion on March 30, 2008, 05:35:59 PM
They should have performed this test with Fe. Unfortunately NMR measurement they did with H and C does not work with Fe. :) This is unrelated to SM TPU research.
Iron 57 has NMR frequency of 3.237778 relative to H1, so its frequency in the Earth's field should be around 6.475KHz.
I know iron 57 is quite rare, but Spherics did not specify which isotope of iron he was referring to, and iron 57 is the only isotope that exhibits NMR if I recall correctly.
Eldarion
@Eldarion
Could you please explain how you arrived at 6.475 KHz?
I came up with a different frequency:
According to Wikipedia -
http://en.wikipedia.org/wiki/Gyromagnetic_ratio
f = (gamma / 2pi) B
Gyromagnetic Ratio (rad T-1 s-1) :    0.8661 x 10 7
Total Magnetic Field Component in my area : 49,850.9 nT
(0.8661e7 / 2pi) ? 49,850.9E-9 = 68.7165 Hz
-Duff
MACEDONIA CD
HI
  FOR S.M  IF is here    man how  long time you whill   keep dis  secret  WE  HAVE HERE IN THIS FORUM    HAVE TO MUCS  THEORY  IS  TELING  OF DIFERENT PEOPLE  OF  ALL THE   WORLD   WAY   YOU CAN  TEEL SOMETHING    AND HELPS TO  GOING IN THE  RAID WAY   OF  OUR   THEORY    I DONT  WHANT TO TEEL ALL SECRET << BUT TELL  AS  THE   RAID WAY TO FIND DIS  >>
I HAVE LEARN  AND   AND   I SEE  ALL THIS  THEORY IS POSIBLE   BUT   I DONT KNOW   HO IS THE TRUE   THEORY   OF YOU
IF YOU HAVE  THAT  DIVICE  HO HAVE ABLE TO SAVE THE ALL WORLD   WAY  YOU CAN  HELP  OF  ALL MAN  KIND    <<THE  < GOD HAS  GIVE TO NIKOLA TESLA   ALL THAT  SUPERIOR STUFF  TO   OPEN  WAY   TO GOING   TO BE PERFECKT WORLD
>>GOD GIVE  ALL THAT  FOR  TO BE PERFECKT   IF THE  GOD  HAS TOLD YOU  HOW TO MAKE  <LETS SAY PERPETUMOBILE> WAY  YOU DONT SHARE   YOU  DIVICE
IF  YOU DONT WHANT TO TELL EVERYTHING  THEN SEND  ANTHER
VIDEO    NEW  OF  YOU TPU
MAN   IS TO LONG TIME IS  10 YEARS
I ONLY  NEED  IS  JUST   TO TELL THE RAID WAY TO KEEP GOING  FIND  HOW IS WORKING
<<P.S     IF THE ONE LIFE  OF ENY  MAN IS  TO   IMPORTANT  THEN  ALL MAN OF  ALL WORLD  IS  NOT IMPORTANT   >>
I LIKE TO  SAY  S.M  MAKE  YOU   FINAL STEP    AND  MAKE RISK  YOU  LIFE  TO TELL  THE TRUE
THE   FUTURE IS IMPORTANT    TO IMPROVE  AND  GOING  TO MAKE BETER WORLD
THE <<Nikola Tesla   HAS  SHARE  ALL  THAT 100 PATENTS FOR   ALL GOOD  OF THE WORLD
           Steven Mark     I HOPE SOME DAYS    THE FUTURE CHILDREN   WHILL BE SAID
             NIKOLA TESLA HAS   MAKE ELKTRICITY
         BUT S.M  IS  MAKE  ELKTRICYTI   HO IS FORK   PERPETUAL WAYS  ;) ;) ;)
