Gravity Magnetic Motor
Started by TheOne, March 29, 2008, 12:33:58 PM
Quote from: Omega_0 on June 23, 2008, 07:38:20 AM
My guess on how it should work.
With the correct measurements and what not that might work.
Omega_0
hydrocontrol
Seems like only half the possibility is there. Why not extend the offset shaft on the wheel to the other side of the wheel and have an identical lever arm and magnet assembly on the other side. Having double the push energy from dual magnets you could then increase the 'flywheel' weight which should increase the power without having to add another wheel.
hydrocontrol
Okay.. brain far* there. Of course if you extend the arm to the other side it would hit the support for the wheel hub. Duhh. You can get around this by having the wheel turned and supported by the rim and not the hub. I will have to see if Sean have any luck before I try..
AB Hammer
I will be curious to see how the trigate work with it.
@Omega_0
I looked at your animation and it seems to me using two magnets that attract may be a little tough on the return.
With out a dream, there can be no vision.
Alan
