OU/COP>1 switched cap PS cct like Tesla's 'charge siphoning'
Started by nul-points, April 04, 2008, 11:49:23 PM
alan
"the excess energy is manifesting both in the capacitor's stored energy and the charging energy of the associated work done in storing it - it appears that both energies need to be utilised to achieve efficiencies > 100%"
stored and work done, arent these exactly the same? :P (excluding resistive losses)
poynt99
Sandy,
Would you mind posting your spreadsheet?
Thanks,
.99
HEYDUDE
QuoteSandy,
Thanks,
.99
Could be where the "Overunity" is hiding !
nul-points
Quote from: alan on December 13, 2008, 10:27:30 AM
hi alan
no, they're not - in two senses...
the text book treatment of cap charging says they should both be the same VALUE - but not the same physical energy
  eg. text book would say that to store 2 Joules in a cap requires a total of 4 Joules - 2 end up stored in the cap, 2 get dissipated as work - therefore, the efficiency of charging cap: 50%
however, i've found from experiment that although the two energies are SEPARATE they are not necessarily the same value as claimed by the text books
eg. from experiment,
  charging 196uF cap thro' 2.5mH inductor and 10ohm load:-
  (component values all measured)
charging energy (charging pulses thro' load):
  1.12mJoules
stored energy (final discharge thro' load):
  0.97mJ
both values measured & calculated from voltage waveform across the 10ohm load resistor
discharge energy confirmed by C2 final stored voltage, 3.12V:
  0.95mJ
ratio of charging to stored energy: 1.15 to 1
which is CLOSE to the same value - however,  tests with a smaller C2 cap value show a value for this ratio of approx 4 to 1
so - i think the answer to your question is - no - not the SAME energy - and no - not necessarily even the same VALUE of energy
to be fair to the text books... the equations they quote are possibly correct for continuous current flow between charged & non-charged caps
my results are showing anomalies for switched (ie pulsed) charge transfer - and adding series inductance in the CR output path
i believe the 'classical' equations are incomplete/insufficient  for these switched charge experiments - we're seeing anomalous charge gain - and therefore a charge gain MUST be accompanied by an energy gain
the measured results confirm this last statement
hi Poynt
yep, i'll send you a .XLS file (Excel 97 version, i think) with data from the results posted on the 'Latest' page on my website
all the best
sandy
______________________________________________________________________________
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc   ...bringing you measured Overunity results since May '08
alan
"eg. text book would say that to store 2 Joules in a cap requires a total of 4 Joules - 2 end up stored in the cap, 2 get dissipated as work - therefore, the efficiency of charging cap: 50%"
hmm, never realized this, thanks for pointing out.
