OU/COP>1 switched cap PS cct like Tesla's 'charge siphoning'
Started by nul-points, April 04, 2008, 11:49:23 PM
nul-points
hi Alan
further to Gyula's help for you in tracking down those papers, Bearden has actually published a schematic for a cap 'step-charge' circuit:
  http://www.cheniere.org/techpapers/Final%20Secret%20of%2015%20Feb%201994/index.html
hope this proves helpful, too
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
pese
MinEth3r
About Step-Charging
It does work indeed, the step charging idea: patents exist on using noisy current for charging, also using less voltage near the end of the charging cycle, in order not tu buck too much against the charge of the capacitor/cell.... one can monitor coltage using indepedent and generic cell monitors, with let say a light detector to enable sylcell(tm)/pacemaker functionality&reliability, let say mission critical systems would double those control cells, would hook many dormant fail-safe counter-meausre in the mix.
Anyway! Not simply a second order system.... one can "move" charges using only voltage, egg before the chicken when thinking about the control mecanism, but the smaller scale can make it appear an insignificant energy loss... what makes life great, high-level feedback mecanisms on the physical/dead world, on other living beings, or would those be only interfaces... one looses weight when "disconnecting" :o|
So much more out there, biological signals: Benveniste, Co-Operative Healing, chinese guys @ quantumbrain.org, lots of examples, the chi....
'Dead Energy" and you get taken away, too frightful for the economy?! Worse law is an absence of laws, one has to think, to design before hand. The single most simplest layer at the bottom of it all... efficient solar panels from the 60's, even higher than 70% documented on Rex Research for example, it's known. We can do it, only one must not exagerate, one has ti be responsible with this kind of technology at his fingertip, no drone army nor autonomous drone armies ;o)
MinEth3r
Sorry for the previous, inspired late night post :O)
As for newelectromagnetism.com, have a look at this
http://www.distinti.com/docs/cap_anom.pdf
Also, this patent is dead simple, great idea, pretty interesting:
US7085123 @ pat2pdf.org
One lets the capacitor do the work, not the battery, the graphs speak for themselves!
nul-points
hi all
i don't have any first-hand experience of Bearden's step-charge circuit - i've referenced it above only because alan was looking for a paper, quoted by Bearden, relating to that process
having said that, the basic mechanism of transferring charge from a voltage source to a load via a 'collector' is similar to the circuit i use to switch charge - and of course, i can confirm that my switch-charge circuit does produce results which indicate OU operation  :)
one notable difference is that i force both the final charging & discharging current of the output capacitor to flow through a load resistor to avoid the automatic 50% energy loss which would occur otherwise
MinEth3r, thanks for the links - i'll go & check them out
all the best
sandy
