can any of you answer this?
Started by redriderno22, April 07, 2008, 09:23:09 PM
sm0ky2
thats essentially the basis for parallel data transfer.
each 2 wires represents the "circuit", and its either "on" or "off".
thats all the computer knows.  when you have multiple pairs, you can transfer info in multiple streams, to move more faster.
such as sending and recieving at the same time, or sending 2 data streams at once.
and yeah, the cable installers should know better, i did that for a few years, and had to learn all about the engles you can/can't make with your runs.
fiber is even worse
redriderno22
How did we get off topic?
O well ;D
nitinnun
* matter is just crystalized energy.
(proton torsion unfreezes it. electron torsion freezes it)
* electrons do not jump from atoms to atom, to create electricity. that is a lie.
instead, negative magnetic energy transfers between electrons. AKA "hot electricity"
(cold electricity transfers from proton to proton. cold electricity IGNORES electrical resistance!)
atomicX
Red,
man... you should have stick to your instict.  If you like this you can keep it.
This universe is a fractal.  Atoms are just like solar system.  Electricity is ineraction of mass, magnetism is a psuedo energy.  Each time two mass object collide it gives out a pseudo force 90 degree.  This psuedo force is electromagnetic waves.  There is no such fix electron size.  Just like earth and mars.  They're electron to the sun, but they ain't share the same mass or size. Light are just a junk of mass that is hella small.  The reason it travels at c because that is its terminal velocity.  Gravity is little jingy vibration of all atoms on earth combine.  Just like sound wave, it can levitate stuffs.  So if you shoot ultra high frequency electro magnetic wave into an object, it'll vibrate and can levitate or gain mass.  DC current is ultra high AC current, and it has mix frequency.  Frequency is intensity, voltage or force is the magnitude.   Everything vibrate gives out continuos energy, the universe expands on this excess energy.  If you perfectly trap a mass, it'll explode sooner or laterdue to energy build up.  Heat is large mass vibration, electricity is small mass vibration.  Different in voltge is different in vibration magnitude.  There, what did I miss?
Oct. 2008,only to remember:
since 1935 , by Chadwick and v.Heisenberg-Consensus the atomic structure is defined
as based by protons/neutrons and not more protons/electrons.
There are not to find electrons in the atomic structure, ergo only molecular importance.
Never forget in some calculations the spin-orientation defined sub-atomar-elements,
proton and anti-proton, neutron and anti-neutron,..... but also the existence of anti-electrons.
We can "complicate" the hypothesis by use of Bosons,Fermions and more of these
"little cosmic Bauelemente".
GN
     CdL
