The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
pauldude000
@all
Here is the 555 slaved circuit schematic:
and a direct link: (so that you can view the WHOLE thing up close in explorer or firefox)
http://www.randallsteward.com/TPU/pauldude000/pictures/3555basic50contduty.jpg
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
@art
Just remember a few things.
1. Use TS555CN's (ST Micro) They are cmos and stable to 2.7 Mhz, and I have not tried with others yet.
2. When testing with dual channel on your scope, remember that one WILL appear to have jitter towards the other, due to the phasing. (You will see what I mean. Check both outputs, you see jitter, check one THEN check the other, and you find the output rock solid for both.)
3. Get a small handfull, as I have noticed one out of the three I tried is not very cooperative, but worked fine when changed out for a new one. (you may have to match three or four.)
4. Play around with it, and do not be afraid of experimenting with it! (555's are cheap, even if you burn one up its no prob.
5. On my scope, trace overlay was exact as to pattern match (frequencies precise).
6. Note that on the circuit I built, I left out the .01 caps. I also tried without the timing caps. (gives highest frequency range, but the out voltage and waveform suffered)
I think Jameco carries the TS555CN's. Do a search on Yahoo if necessary.
<500 khz should work with any 555.
>500khz only a handfull, and all cmos not bipolar.
Paul Andrulis
buzz-ard
Just today I picked up a couple of 556CN, dual 555s on one chip, 100ns rise/fall. $1.99 at Rackity Shack. Dunno if they're any good or not, but for the price you can't go wrong.
You wouldn't believe me if I told you.
pauldude000
@All
First, for the black hats... I have made this abundantly clear everywhere else, I will here as well in case you missed that memo. I am not going to build weapons for anyone, anywhere, anywhen, ever. period. Get over it. Don't bother with the reports, they have probably been filed A LONG time ago, from various places from back in my physics days.
Concerning one of the few scientists on this earth whom I have much respect for...... Nikola Tesla
Why respect him? He didn't buckle under opposition and criticism. He allowed people to think whatever they wanted concerning his ideas. Concerning harmonics and resonance. Notice I didn't specify electricity? He was about harmonics... in EVERY form. You might say the man loved harmony, and looked at the physical world as a symphony of harmonic interactions of all types.
I have heard much trash BOTH ways concerning this man, but most by those whom idolize him... Yes, Now, just as then, his FANS are his biggest detriment.
His fans have more to do with his popular labelization as a nut than his theories ever could. Take out the mysticism, the half-baked ideas, and  the sheer garbage touted about his "known" concepts, and you have but a handful of truth left over. To give understanding of the man, I am going to have to EXPLAIN resonance, since the sheer multitude do not seem to have a clue.
You have resonance, then you have TRUE resonance. Most of what is labeled as "being resonant", is at best in description harmonic. TRUE RESONANCE IS ALWAYS CUMULATIVE IN EFFECT. For instance, truly resonant frequencies don't necessarily superimpose, they tend to amplify. The same is true of mechanical resonance.
True resonance also tends to destroy. THAT IS WHY THE GOV CLAMPED DOWN ON THE TECH. True resonance will destroy a close but non-resonant receiver. That is why engines at certain RPM's shake themselves to pieces, that is why overunity devices of any description go into runaway mode.
"True resonance" deserves a title separate from mere "resonance". Resonance is merely sympathetic vibration. True resonance is MUTUAL INHERENT resonance. True resonance in any form actually scares me. If uncontrolled or unfocused, it will destroy anything merely resonant within it's sphere of influence.
For instance, if I make a self amplifying truly resonant field of any kind (sound, magnetic, mechanical vibration, etc...) whatever it influences that is resonant in any manner will vibrate. The problem is that it will not vibrate properly, it will not share the EXACT frequency of vibration. This will cause the field (which is by definition self amplifying, therefore continually getting stronger) to superimpose more and more energy into the sympathetic object, which will fight against its own NATURAL INHERENT resonant frequency, which is close, but not exact, in reference to the superimposed field.
This means that the sympathetic object quite literally "shakes itself to pieces" in some manner. Put quite simply, it has no choice but to self destruct, as the impressed field eventually grows stronger than the forces which hold it together...... Now for the crutch of the matter. It is practically impossible to build a device which is truly resonant to a given field. You can only build a device, THEN find it's true resonance frequencies.
WHY?
Good question. Do you know the exact mass, number of free electrons etc.. If you do, can you build the device with tolerances into the ten thousandths of an inch? THIS IS THE KIND OF INFO AND BUILD YOU NEED to design for true resonance. Not impossible, just more difficult than I can achieve. (Unless you have a team of machinists, EE's, and Physicists, it is beyond you too.)
THAT IS WHY OU DEVICES ARE SUCH A PAIN TO REPLICATE. Even if you had blueprints, you would still not achieve a working device without experimentation.
Now, why does tesla gain my respect? He was not a mental failure.
There is only one way to truly fail, and it is the worst type of mentality, and that is not to try. By not trying, you are guaranteed failure. Even a half-a$$ed attemp has a small chance of success.  Most scientists (whether you like it or not) fall into the failure category, as they CAN think outside the box. They just refuse to even try, therefore gain NOTHING truly new, but modify the heck out of ideas they do not even truly understand.
A handful have my respect, whether I agree with them or not, as at least they TRIED.
Those whom sit back and laugh at, or abjectly write off, concepts before attempting to understand them merely demonstrate their own inadequacies and inabilities. To bad they are self-imposed, more the shame.
If some think this last arrogant...it may well be. I don't know. I just know that it is true.
Paul Andrulis
sparks
    Well said Paul.   I  never liked the tpu dragless alternator because of it's ability to reach resonance with Earth's spin energy field.  I'd rather use the kick to catalyze mass to energy conversion in a linear designed machine like Tesla's machine for wireless energy transmission.  Then let the Earth recharge the copper mass.  No need for resonance. Resonance gathers energy from time compression.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
