Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
Pirate88179
@ Gary:
Nice coils.  About the rebar tie wire, did you test it with a magnet?  I almost used that but when I was in the home building supply store, my magnet (neo) had very little attraction to it. (Not much iron in it)  I found some fence wire that it was hard to pull my magnet off of so I used it instead.  I am not a chemist but I figure if it is strong on a magnet, must be a lot of iron content.  Same with the rebar I almost used for my core, very little attraction. So I used the galvanized (zinc coated) spikes which were also strong magnet pull.  I am sure all of these products vary from supplier to supplier and place to place.  Just a thought for you.
jeanna
Gary,
What happens when you hook it up the way Tesla invented. He said it was a great improvement over the previous way.
Make the inside copper wire longer enough to attach to the outside iron wire. Then I guess you will be left with just 1 pair of leads.(makes things easier for me  ;D ).
Tesla said what he was improving was the self dampening (I chose that word) effect of the pancake coil. I am assuming there is a similar dampening with this bifilar pancake.
I promise to wind my own   ;) , but I would love to know the difference sooner.
jeanna
resonanceman
Quote from: Pirate88179 on April 24, 2008, 10:53:04 AM
@ Gary:
I just checked my  rebar  tie wire ...... my neo's  stick pretty good .    good enough that I could not pull  them off  with  slightly sweaty fingers
Has anyone  else been shorting out  their  coils   for a while to  get the  current  up ?
Mine  has been  shorted most of the time for around  6 hrs now .
WHen  I disconnect   the  jumper  the current  readings go up  pretty fast ........then  level off ......... amd then slowly  drop  a little .
The  peak   this time was  1.395  mA ...........  after about  5 min  it is holding  at 1.391 mA
I am going to leave for a couple  hours ........I think I  will leave it shorted
gary
jeanna
Gary,
I don't  have any core at all .......I am just measuring  between the copper and iron .
doesn't seem to matter  what end .
The only thing I did  is  get it wet
even the inside of one to the outside of the other?
jeanna
Pirate88179
@ Gary:
I am glad you checked with the magnet.  I know that saved me a lot of problems on my first two coil attempts. I am going to try to get some more wire this week to try one of these.
Maybe I should try shorting my buried coil for a while?  Hmmm.  I'll try anything to up the output. I believe Chad has our mA record here with almost 150.  This is getting somewhere.
