Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
1tesla01
Jeanna,I work in a scrap yard!!!!!!!been doing for 40 years I reconize (flat wound generator copper wire)when I see it.I would go to a #10 on the secondary though but 12 will be just fine!!!!!!!!!!! will have to spin some #8 to figure out what size bolt.will make a nice electro magnet.I wonder if it can be made with some N50 or N52 magnets as a bolt ??? ??? ???
jeanna
I will post one of today's tests only.
The picture shows roughly how it was tested.
I hooked the copper to copper with the meter between
Just by itself that reads 0.533vdc
I also connected the other copper on the left one to the base of the one on the right.
by itself this reads -0.170vdc
So, together the meter should read 0.363vdc (when it looks just like the pic with both at the same time)
but instead they read 0.710vdc with 0.835mAmps
I was reluctant to use this example because if that -170 were shifted to +170 then the 2 would add up. The thing is that - is real. I took 14 readings and only 4 of them were -.
This same odd negative shift occurred in one other reading, too.
Have a look. I will read these again tomorrow.
jeanna
jeanna
Andy,
I didn't mean that. I meant where did you see something that made you know it was wires of that size?
in the drawing?
thanks
jeanna
1tesla01
28 turns x 5 primary and I counted 41 turns on the secoundary but Im legaly blind so you need some one to blow this up and check it.the gage iron wire needs to match the size of the copper,probaly bailing wire for the secondary    :o Andy
1tesla01
Jeanna,I blew up the patient where i could see it and i saw the flat wound wire that is transformer and generator wire I buy it every day.Im the shop forman that buys all of the copper,aluminum,brass,stainless steel,I grade stainless steel almost by eyesight,I grade all of the copper,and brass.I buy silver,and recycle gold also in the yard.!!!!!
