Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
Michelinho
It's funny that when I reread myself after a post ideas sprout.
QuoteThat would give the possibility of higher dc voltage not pulsed as the cells are set in anode cathode pairs.
There are also two possibilities in that scenario.
One come from connecting for high dc current, the two 5cu and the two 6fe terminals in parallel connection. Each cell is conditioned the same way but with reverse polarity.
The other where higher voltage is needed over higher current. Then you connect two or more cells in series.
That too has 2 possibilities.
You connect the 5cu of one cell with the 6fe of the other and use the 2 free posts for the load.
Or you connect the 5cu  of one cell to the 10cu of the other cell and the 6fe to the 10fe in a resonant cell. There too is a possibility of alternating potential.
This Stubblefield cell is fascinating... What can I say.  :o
Michel
Michelinho
Re:
I think it is Pirate who posted the attached picture. a while ago. The blue pointed cells are huge.
4 Spikes welded one in each corner of a square beam with a big bifilar coil and the control coil over it. Just pretend that the whole cell sits on an optional platform. You have an iron core with a special bifilar coil Fe+Cu and an exciter coil. Maybe you need the moisture for the iron oxide, maybe not, that part is still a mystery but from what I recall, Tesla ran a car for many hours with a shoe box beside him with only coils and a dozen of vacuum tubes (diodes and rectifiers) inside. I have seen a few videos and old articles with these pretensions and all had in common iron/copper coils.
Maybe the ground has nothing to do with it. It is all in the MIND.
Happy research,
Michel
storre
Welcome michelzinho!
Looking at this today I wondered what you thought about the collapsing magnetic field.
http://jnaudin.free.fr/html/NWMkeys.htm
Seems that is the big key to tap into this other type (radiant?) energy.
My idea was to use a NC reed switch. I've got everything I need but have been a bit side tracked by John Bedini and Newman! :)
My coil is still next to me and I plan to rewind it with more wire and using cotton on both wires to avoid any possible shorting. I think mine is shorted somewhat now because I'm getting strange readings. It has cotton on the copper wire and the zinc coated iron wire is bare. I plan to use the cotton tubing on both and will report back soon. :)
Michelinho
Hi storre ,
QuoteLooking at this today I wondered what you thought about the collapsing magnetic field.
I love collapsing fields and the nice bemf they produce. Here is what I see.
A coil is a big resistor. The bigger it gets the more it morphs into a capacitor. So you stuff it with full electrons and as few come out at the other end, they are compressed by the source of power. Then you suddenly remove the source of power and redirect the coil into an empty reservoir or the source. It captures the fast collapsing magnetic field into a potential much higher than the input as it is not restricted in its path by the same resistance when it moves to the reservoir and fading echoes follow. Back EMF are not over unity. It is energy that is otherwise not used.
But that has nothing to do with free energy and the Stubblefield cell but still fun to debate.
Take care,
Michel
storre
I've always seen the ns coil as a combination galvanic battery, electromagnet and with a reed switch (operating off the mf of the coil). When the energy builds up enough to create an electromagnet then because of the magnetic field, the reed switch will open and thus collapse the field which then causes the reed switch to close (it's natural state) and the the process repeats over and over. Then as this primary self pulses it creates an ac? current in the secondary single wire wound over it with much more turns than the primary.
