Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
resonanceman
Quote from: jeanna on April 20, 2008, 02:43:15 PM
How do you test the magnetic part with a cap?
I like testing with a cap in general because the meter is not able to mess with things, but how do mean to test the magnetic part?
The cost is the reason I was and still am making rather diminutive coils. I can see the effects and change them for less money. When I think I am ready I can pay the big bucks for some plenty-copper-wire.
Jeanna
I am  doing  almost the same thing   you  are  doing  ........only  you are  looking for a result  that is  both  galvanic and magnetic .
For a galvanic  reaction  you  are looking at how  2 metals  react  with water .
In my opinion   galvanic  action is not  true over unity  because  it will eventually  destroy the cell  as  it created energy .......it is a chemecal  reaction
I am looking  for  a magnetic reaction  or rather a difference in  magnetic  reactions from  different metals in a  magnetic  field   ( earths magnetic field )
by using a cap  I am also  ruling out  self  created  magnetic fields that a coil might make.
So far  my  copper / iron  cap     creates   between .5 and .6 V      but no measurable current .
I  hope this answers your question
gary
1tesla01
Hello Guys, I most exclusivly use Tesla bifilar flat wound coils # 8 or larger size wire.The bifilar phase shifts to 180 degrees out of phase-phase shift.This appears to be a direct short .There is a tap where the two wires come togather.The bifilar properly built "IS" a capacitor.Then there is a monster ground as per Tesla.He always used monster grounds of the best copper this was because of the small resistance."Olms law".(One of the coils I built was 25 to 28 turns of #8 copper wire.I had some wierd waves come off this configiration,house hold voltage was 140v at 15amps.)*Mabe this information will help*.My new coil I'm working on is a # 1 size copper cable this is a little dangerous I'm saving my money to buy the proper test equipment to test some new generators.Wire the capacitors in the "Tesla Switch" configuration would be my thoughts on regular caps, because this gives the 180 shift."Tesla said "ALL POWER SPINS OFF {ZERO (- 0 -)}" ALL Bifilars will give you these mathmatics.Trifilars are different.Inside of a silinoid gives this same scalar wave can be amplified with a regular Tesla coil sitting on top.Sorry I have been gone for so long. Some people offered me 225,000 usd and they had a bad attitude and p.s. me off ,they demanded me to sign a contract with them.This information will give us FE and Antigravity.Use this wisely.Andy McQuerry (phononstring@yahoo.com)
resonanceman
Quote from: Pirate88179 on April 20, 2008, 03:53:34 PM
What is it about the copper itself?  And its relationship to the iron wire?  I was always wondering if we could use another metal (cheaper) than copper for the wire?  The only other thing I could think of that we could get easily would be aluminum wire.  Maybe this would work better?  NS did not have access to AL wire at that time, I think, so his not using it might not be because it would not work?  (It might work better) Again, so many things to experiment on and explore. (So little $$ for materials)
one of the reasons   I   made my cap is to  check out  the  interactions  between  different metals
I was very hopeful that  aluminum  would  work  out .
my readings  with aluminum  / copper   and aluminum  /iron  were both very low ..... of course  I was only  checking  dry  voltage     ( non galvanomic )
If you  get a very good  galvanic   reaction it still might work in  the coils .
gary
resonanceman
Quote from: 1tesla01 on April 20, 2008, 05:06:52 PM
Welcome back  Andy
As  someone that  has worked with  Tesla  bifilar coils ......  do  you think that winding   a Tesla  bifilar with one coil  copper  and one iron  would  make  something similar to a  stubbfield  cell ?
gary
1tesla01
Gary,There are several types of Tesla bifilar, flat wound and spool,are two types. The answer is yes!!!!!!!! A Tesla coil mounted on top, amplifies the scalar wave drastically.Phone me 870-862-8020 Andy McQuerry
