Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
Pirate88179
Here is a video of my earth battery and Fuji circuit running 400 leds:
http://www.youtube.com/watch?v=agqKEed7AOI
More to come.
Artic_Knight
thanks guys, you always were my favorite :) so this doesnt look like the same old EB thread? what happened? i havent been playing with EB's as you can tell for a while.
jeanna
Quote from: Artic_Knight on June 07, 2009, 06:23:42 AM
this doesn't look like the same old EB thread? what happened?
Here is where it all began.
localjoe changed the name a while ago, but this is his original EB thread...
This is the one with all the background information on probes-in-the-ground
http://www.overunity.com/index.php?topic=3500.0
jeanna
Nabo00o
Hey everybody, I was first thinking on posting this at the main Stubblefield tread, but then I thought it would maybe be more on topic placing it here.
I've recently been playing a lot with the solid state version of the Bedini SSG by placing a car ignition coil at the output instead of a battery. It can transmit the electric fields at a distance and light all kinds of gas bulbs.
If I connected a bulb between it and a large aluminum surface I could get it to light, and recently I made a simple earth connection by hammering a normal copper tube down in the ground, some meters below the room I'm using.
With the earth I got a much better reaction from the SSG, being able to light much more with 'Just one wire'....
I know this because I'm running the SSG of a battery so there is no other earth connection for it to enter.
I've also placed a Am/FM radio close to the setup and it pick up everything I do.
Then I noticed something interesting. When the SSG was completely powered down, I could here a click in the radio when I touched an aluminum plate with the earth wire, it responded more the closer to the plate it was placed.  The plate was not connected to anything, it was just lying by itself in the room.
I then tried to connect a small neon bulb between the aluminum plate and the ground and it lit up, but very dimly! As far as I know, a neon bulb normally requires about 60 or more volts to light up, and no galvanic cell can put that much out! There is very little current here, and the meters can't read anything (I got both an analog and a digital multimeter).
I think this is related to the Stubblefield batteries, even if I'm using only a single rod, maybe it is a clue to the real workings of the battery. I don't think galvanic reactions has anything to to with these batteries at all, so maybe the placement of two rods is just something we unintentionally want to do because it resembles the common battery more????
Anyway, I think this is interesting, and I've tried as hard as I can to remove any other source of power which can react to the wire. And no, we don't have any power lines in the earth around here, it all goes by the air  :D
Static energy...
Dynamic energy...
Two forms of the same.
Pirate88179
Naboo:
That is very interesting indeed!  Yes, there is far more going on here than galvanic that much I can say for sure.  Please follow up on your discovery and do some experiments.  I would be very interested in your findings.
@ All:
I am re-posting this site which is a calculator to determine the magnetic deviation and dip angle for your area:
http://www.ngdc.noaa.gov/geomagmodels/IGRFWMM.jsp
I hope this helps.  It is a good site.
