Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
resonanceman
Quote from: jeanna on April 21, 2008, 12:18:47 AM
I probably should go to sleep instead of ask another question but... ;D
I can't picture this. the pancake is flat on the ground like the picture ok. And the core is a sheet in the form of a disk? I can't follow the core part?
Anyway it seems to me that it wouldn't need the corepiece or anything else the way he wrote the patent. but lets say it does and you are going to hold onto some of the mag field you produce with the coil as in the NS core piece 1 primary, where would you put the core?
a pic a drawing?
jeanna
ps
yes gary, that is like what I thought Bill was doing. stab the middle like the record spindle.
Jeanna
I am not sure  what Bill means  by a disk  shaped core.
To explain my idea of a  core .........if you  put the  pancake  on the ground ........and  stuck  a bolt  or piece of rebar into the  ground  in the center of the  pancake ....... That is all that there is  to it.
you may  be right....... these coils may not need  a core .....
gary
Pirate88179
@ Andy:
So, you are saying that it does not matter if the total copper is wound or straight?  Are you then speaking of the total mass of the copper then?  This would make some sense to me based on earlier experiments for upping the power over voltage.  Great input, we appreciate your postings.
jeanna
Quote from: 1tesla01 on April 21, 2008, 12:33:20 AM
Gary, Footage of wire is where the voltage is for example a 24 foot solid copper rod in the ground is 24 volts.
PLOP! goes the strawberry.Same with the free electrons.Andy McQuerry
So now hold the maple syrup and pass the strawberries ;D ;D
Andy, I thought from reading the patent that just a bigger diameter does the trick and we really don't need to make 2 layers. right?
I think this is another whole avenue for  research.
What have you made from this patent? It seems really strong to me. just wind more wire to make it longer bigger diameter and wow.
and it is all insulated so just do it. no wrapping. I better go to sleep! ;)
thanks Andy
jeanna
Pirate88179
@ Gary:
What I mean about the disk shaped core is this: Picture the pancake winding wound around a core the thickness of the two wires stacked upon each other in bifilar fashion. So, if each wire is .125" diameter, then stacked they would be .250".  The "core" in my idea would then be a round piece of iron 1/4" thick by whatever diameter you wanted.  Or, in your stacking scenario, you would simply slide the multiple pancakes over a center pole (rod) for the core.  Am I explaining this better?
jeanna
The thing about the NS battery coil is that a small amount of galvanic action produces a whole lot of power. we just need to get the proportions right.
Im outta here
jeanna
