Cap-Z-ro
Same in my neck of the woods Bill...I attribute it to the recent increase in chemtrail activity.
As you know the trails change a clear blue sky into a milky white haze...thereby blocking the sun.
Regards...
jeanna
Hi everyone,
I just put together many pieces I have been working and re-working for some time.
Some of these pieces some of you may recognise from last year. They were hunches then and I think I can see how they are fitting together. I won't be setting out to prove it for a while because it is not the right time of the year yet, but for some of you, this is the right time. So todays offering follows.
1- The NS generator is at once a galvanic battery which powers
2- a self contained joule thief including the
a- transistor, with a
b- base bias and a
c- straight (not toroidal) core with a
d- heat sink and
3- secondary for using the output.
1- we have worked on the galvanic part no more needs to be said.
2a-  the transistor is created by the 5,6 wires being connected together, and the 10's wires that are shown sticking up in the patent and about which NS says to leave them alone, are in fact inside a metal ball. This is where a tiny spark gap is set up for each end and when the current/voltage arrives at the top it makes a plasma arc and through the interior of the metal ball connects to the other wire. This is very much like the C and E in a transistor. In this version he is using the transistor as a switch.
2b- the base bias is produced by the fact that the iron wire has more resistance than the copper wire.
2c- yes, straight but with a soft iron core not a steel core with zinc coating. I don't believe any of us has made one yet with a true soft iron core.
2d- heat sink. The whole thing by virtue of its being wet and sunk into the earth keeps all the parts cool.
3- secondary. None of us ever got the secondary to produce.
Maybe.
I had one that was closely wrapped right onto the final layer of the primary. It had many fewer turns than either wire of the primary and it did absolutely give off voltage. It gave off voltage from everywhere. I even wrapped a little secondary around one of the wires, I believe the 5 or the iron 10 and it gave off the same voltage.
This is odd that the voltage was the same for 12 turns as for 60 turns secondary. But maybe not.
4- The only part I have not mentioned yet is the magnetic currents on/in the earth., the so called teluric currents. It is possible that the pulsing of these added to the effect of my secondary.
EDIT:
IST made an interesting contribution to this concept last night. He is hand pulsing the battery. The joule thief is making its spikes, but he is adding to it by hand pulsing the battery. I am drawing a link here between this pulsing and teluric currents. thanks ist.  watch this and see:  http://www.youtube.com/watch?v=g1f9p08HRHg
BTW no one ever commented on the results of this coil but I think it was only because we were all focused on raising the primary to a higher voltage. 0.385v just didn't seem worth noticing.
But, now, after working with the elements of the joule thief, I am very interested in continuing this NS generator.
Maybe he did use an arc lamp.
Maybe he was heating his house from a hot plate made hot by the wires connected to it.
thank you all,
jeanna
Pirate88179
http://www.youtube.com/watch?v=XmsDvNDTz_w
@ All:
Above is a link to my latest earth battery experiments where I am lighting an ultrabright 28,000MCD LED using the EB and a Joule Thief circuit.  This is my new set-up using my 2 carbon rods and my 5 pound block of magnesium.  more tests to come.  I just wanted to put this one out there as I have been waiting a long time to do it.
Bill
Pirate88179
I should have explained better.  Last year, I was able to light some leds but they were small and not like this ultrabright one.  Also, I was using a small super then as well.  I will get into these other tests as soon as I can but this is just test #1 for this new system.
Bill
jeanna
This is so great, Bill,
As I mentioned on youtube, I am jealous.
But, I am also encouraged. I believe the reason I had mediocre results last year with my EB's may be partly due to the fact that I didn't use fatso wire on all of the battery parts. I saw the wire on the video, and it really is much thicker than what I used.
It is probably all I need to let the amps flow into my jt and lights.
Thanks again for a great inspiration.
jeanna
