1tesla01
Gary,Old mags some were  magnesium and some were - most were and are today aluminum.look up magnesium rims.lOOk on e-bay there are corvett and other rims that are magnesium.Magnesium hasn't been used for wheels in about thirty years. The word Magnesium got shortened to "Mag - Wheels" , but the name stuck , even after the wheels were changed to aluminum.
Andy
1tesla01
All, Here is some thing I have found. CATHODIC PROTECTION ( CP ) USING MAGNESIUM ( Mg ) ANODE : :
  If two different metals are physically or electrically connected and immersed in electrolyte then some amount of current flows between the two metals. This current is supplied by one of the metals by emmiting metal ions to the conductive environment . This is known as galvanic corrosion which destroys base metals rapidly.
Magnesium (Mg) alloy anodes are having greater driving potential than zinc (Zn) or aluminium (Al). So that magnesium anodes are suitable for the protection of pipeline, tanks, condensers, water boxes, heatexchangers, ship hulls, boilers and marine structures from corrosion.
: : MAGNESIUM ALLOY ANODE ( sacrificial Mg cathodic protection anode ) : :
  According to the chemical composition Mg anode can be classified as high potential magnesium anode & low potential Mg anodes.
High potential magnesium anode is made from high purity Mg, which produce higher driving volt. So that it can be used for high resistivity soil
1tesla01
@All,        If I did my math correct that would be .157777 amps pre secound per pound @ 550 AMPS PER HOUR PER POUND THIS IS A FANTASTIC FIND !!!!!!!!!!!!!!!!!!!!GREAT RESEARCH!!!!!!!!!!!!!!!!!gypsum is every where available its called sheet rock in my house on my walls. Seasalt will increase the galvanic action.Andy
1tesla01
Thanks guys, This will go nicely with my 4 inch ground rod solid copper 24 feet long.500 lbs of magnesium =78.885 amps per secound this will give me being conservative approx 96v@78.885 amps.per secound.DC.Andy
resonanceman
Quote from: 1tesla01 on May 10, 2008, 09:31:51 AM
I am  guessing that  these  would make cells  that behave similar to  the smaller versions  of the cells .......... so ........if they are placed far enough apart they should   be able  to be put in series.
8 to 10  of them  should  give  you  between  12 and 15 V  ..... it should  be possible to run an inverter  off of them  directly .......  if some  deep discharge  batterys  were added  a larger  inverter  could  be used part of the time ..
gary
