Is this circuit good?
Started by guruji, July 30, 2008, 04:15:06 PM
guruji
Hi Sandy I had done a capacitor but it's taking a bit long to be energized.I think I should do  bigger magnets and increase coil cores around the rotor for better charging.I saw a guy on youtube leaving the motor off and just pushing the rotor;electricity was generated.
He did a sort of generator around the rotor.
Nerzdishual why you said to use welding rods for coil  cores; are these better?and where I can buy those plastic rollers for winding the coil to them?.
Sorry to ask alot of questions but I am very keen to build an OU motor.
Thanks guys.
nul-points
hi Andrew
what value capacitor did you try (in place of the battery to be charged?) ie. what uF and V values?
yes, it would be good to return again to Malta someday - i wasn't able to see the underground or large outdoor temples - just a small outdoor one
if i get an opportunity to return i'll certainly let you know!
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
guruji
HI Sandy the cap was 35v 200uf.I think the transistor is not closing up completely cause when I used to use a reed switch the caps of any size were being filled easily.
Ok thanks Sandy yes you're very welcome to Malta.
Bye bye.
NerzhDishual
@Guruji,
Why welding rods?
Because I was told so and because I'm always very obedient...  ;D
No kidding and more seriously, please consult:
http://peswiki.com/index.php/Directory:Bedini_SG
http://peswiki.com/index.php/Directory:Bedini_SG:Materials#Magnet_Core_.28Welding_Rod.29
I had removed the 'coat/cover/mantle' of each rod and roughly insulated each rod with glue.
Why had I removed the coat? Because the coat is very fragile/brittle, and I  thought
it was more 'clean' and also because, after all, I'm not so obedient.)  :))
Perhaps I should had not removed anything?. Anyway, you need a core.
I did not purchase any plastic roller. I built them with plywood, 'hole saws' and a
plastic tube of Aspirin or Vitamin C (or any else suitable medication... :)
Best
Nolite mittere margaritas ante porcos.
