HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
EMdevices
Hi Jack,
I believe you will find the information provided by Steven Mark to be quite usefull.   Check out the "The Master of Magnetics Steven Mark" thread up top in the locked threads section, there's also a pdf file Marco composed here (user Turbo, at the time):  http://www.overunity.com/index.php/topic,2383.msg31887.html#msg31887
Here's an excerpt from one of his letters to us:
Think of the power unit as a device similar to a radio receiver. No I do not want to hear feed back informing me that I am trying to convince the world my unit works on radio waves!!!.
But it behaves very much like a simple radio receiver except for the fact that radio waves need to be amplified before they can be of any use to us.
My units behave as though they are variable tuning devices, and we are tuning them to a frequency just like a radio. The closer you get to the center frequency the more power you permit the collector to dissipate into a load.the important difference here is that in the case of the radio, you tune into the frequency and amplify it for use. In the case of my power unit, you create several frequencies within a space of the collector coil's circumference. The frequencies are directly related to the circumference of the collector coil. You can begin to collect the current and dissipate it with no need for amplification because the signal source also becomes the feed for the power source and has the natural tendency to run with gain.  It is important that you note that you can never tune too closely to the exact frequencies of power conversion because the power received by the collector will instantly destroy it. We instead must deliberately tune off the frequencies of conversion in order to make the thing properly work. Remember that it is like a furnace which feeds itself. The hotter it gets the more fuel it gives itself to burn. that is why the control units are so very important. Without the control unit constantly monitoring the frequencies of operation and making the necessary changes to keep the whole thing off exact conversion frequency, then the unit would very quickly destroy it's self.
By the way, have you seen the video of the compass turning violently in the center of the unit while in operation? Notice that when I first turn the unit on that the compass starts to spin very slowly. it speeds up faster and faster until it just stops. When it stops the unit is always operating at about it's design maximum. We never found out why any of this occurred. It tended to reinforce what I observed as the turbine effect. When the unit is shut off the compass starts to revolve again and slowly comes to a rest.
EM
poynt99
sorry for the dumb question:
what is the difference, if any, between the torrent file that jdo is hosting and the files uploaded at MediaFire? isn't everything already in the torrent file?
gn0stik
I believe you may be right about this Jack. It could be a Saturatable reactor LC circuit, or actually, 3 or four of them arranged around a toroid.
EM's post was good for a few reasons, not the least of which were the reference to the "missing video", and the "turbine effect".
The topology I posted about above would explain why it spins up slowly. At first it takes longer for the saturatable cores (mag amps) to reach saturation, than when they are in full operation. Of course the compass does not stop spinning because the magnetic field stops spinning, it stops because it's spinning too fast for the compass to respond. It would also explain a few of his other metaphors. The cannons firing successively, squeezing the hose, etc., etc.
At any rate, did you ever hear of the compass video? Or was that shot during the time that you worked with SM?
Oh, and thanks for this.
Regards,
Rich.
jdurban
I just reviewed the larger unit segment and sure enough the chokes are the outputs.
Another little nugget...
I don't think the smallest unit has power switch. The entire assembly is covered with tape and Steven just walks up to it already sitting on a table and just connects to it. Could one assume that the earliest device was the smaller unit and due to its limited output it was never considered being dangerous left on. This would reveal that the device could run infinitely if not connected to  load! This also supports a phase locked device.
Perhaps the next larger unit with the magnet as a switch was designed as such when it was determined that the output was dangerous enough to warrant a switch. So what? Well it does reveal a lesser important but interesting clue. Magnetic reed switches are low current in this size. This would mean that the switch is connecting the low current/low voltage side of the device or the Primary!
So what? So what if the primary is in fact an antenna, a tuned antenna, better yet a tank circuit? An ordinary tuned tank circuit is designed to favor an in band frequency or wavelength and reject all other frequencies or wavelengths. Well the tank circuit certainly would not be conventional in that there is no ferrite rods or cores visible to maximize Q creating the ideal tank. But what if the target wavelength was very high amplitude in its natural state to begin with or at least a couple orders of magnitude above the ambient noise floor? Theoretically you would not need a tank at all but just a means of capturing the wavelength and introducing it to a matched secondary where the captured wavelength is superimposed over a series of windings that causes the primary and secondary tanks to harmonize with the original wavelength acting as a tickler or excitation wave and the secondary becomes an amplifier of sorts.
Prehaps the whole overheating issue is really the natural result of  gain from the primary to secondary and unlike a conventional amplifier that can be conventionally cooled the TPU's amplifier is a secondary winding of just wire!
Time to revisit our Tesla books.
Windows has detected a mouse movement and will now reboot.
BEP
Great work Jack, Jason and all!
At some point, someone please consider sending discs via snail mail. Cover your cost, by all means. Here torrents are blocked and non-negotiable. Downloading a bunch of 50 or 90 MB files would take weeks. I'm sure like many others, I have no other options.
Thanks,
John
