HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
0 Members and 18 Guests are viewing this topic.
Spider
@all,
I just came out of my bed for this one, it already night here.
Consider this:
Imagine a perfect gyro, spin it up, nothing happens....
Imagine a gyro with an unbalance, like the front wheel of your car. what happens if you spin it up, it starts to wobble. Ever driven a car with an unbalanced wheel up to its resonance, let me tell you, it can shake you car violently. Usualy I try to avoid this speed where this happens.Where does this energy come from?
Now consider a rotating magnetic field in symmetry, rev it up and nothing happens.
Now what would happen if we place a permanent magnet in this field, would it start to wobble?
Is this why SM spins up the TPU, then places 2 permanent magnets in their "recepters" and make the field wobble?
Does this create the release of energy in the TPU?
Would the circumference of the ring have anything to do with the resonance of the wobble?
I wish you all a good night sleep, sweet dreams and greetings,
Rene.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
jdurban
Quote from: Cap-Z-ro on April 21, 2008, 06:03:29 PM
It is truly inspiring the spirit of cooperation I'm seeing here.
I don't know if we will ever really know how the SM TPU really worked...but from what I am seeing here something will be built that will be as good as or better.
You guys are putting out so much knowledge that of of us boobs just may say something outwardly irrelevant which may trigger an idea among with the background to run with it...a lot of things happen that way for people who pay attention to everything.
I am a firm believer in serindippity...my life took many positive turns because of it...there's nothing like having 'Great Expectations'.
Regards...
Well said. I often get answers to daunting questions by constantly stepping back and asking "what is known?" and what is pure speculation?"
As much as some will scoff at this I will take a risk. Edison when faced with a challenging design issue would just take a nap. Often he would find solutions to problems this way. To be honest I do this regularly and it works often enough that I stick with it. If you study the brain especially brain wave activity you will find that just prior to REM sleep you slip into an Alpha state where you remain mostly conscious until you drift off. It is here that amazing clarity comes about. I have used this for nearly 30 years now and most of my inventions and product designs were aided using this technique. There is an out of print book called "The power of alpha thinking" that is one of the better guides on how to do this effectively. In brief you master the art of visualization while in an Alpha state where focus is an order of magnitude greater than the Beta state or full consciousness where we are bombarded by distraction and second guessing. For those who will dismiss this and laugh you at least got a laugh out of it. For those who will take a chance you will be amazed how much more you can accomplish by getting out of your own way. With over two hundred designs and 21 patents pending and issued I have put it to the test and it works for me most of the time.
Flame retardant applied now fire away!
Windows has detected a mouse movement and will now reboot.
poynt99
Quote from: mikestocks2006 on April 21, 2008, 12:19:16 PM
Thanks for the reference, I have looked at that site and a number of others before, they do describe what the DEMOS is (depletion mode mosfet) but they do not have them for sale.
With a few manufacturers names in hand from that website, you should be able to find a vendor or distributer by doing a search. If not, well they aren't common as I mentioned.
Why the interest in depletion mode?
Trying to keep it simple, and allow the system to self tune, find it?s own resonant frequency by default. Then build on that. Remember the old DC bicycle bells? A set of AA or C batteries and simple coil and a leaf spring. The spring by it?s own movement interrupts the circuit, and moves back at its own natural frequency. (function of stiffness, weight etc)
I?m interested in the off part of the cycle. First having a current and then stop the flow abruptly, it would also be in line with RE behavior, kicks, etc.
With some work, you should be able to arrive at a similar solution using the vastly more popular and available enhancement types. SS relays may also be an option.
but hey i'm just a lil' ol' troll
nickle989
Is anyone having problems opening the Zipped archieves in Part 1 .. ? of the DVD video.
eldarion
Quote from: jdurban on April 21, 2008, 07:18:20 PMIf you study the brain especially brain wave activity you will find that just prior to REM sleep you slip into an Alpha state where you remain mostly conscious until you drift off. It is here that amazing clarity comes about.
I have experienced (and used!) the same phenomenon--interesting to know where it comes from!
@all,
Attached is a winding configuration I see in all the TPUs and have started to run tests on.  The tests are not showing much power out at this point, but they are (possibly) showing kicks building on each other...I have also attached a scope shot of that happening.  This was with 19KHz 50% duty cycle pulses applied, and an IRF510 MOSFET driving the "control" coils.
Something interesting is that this ties into what Spherics stated in his second post; this configuration is also readily apparent when you scrutinize the two open devices.  Having the delay coil wrapped around the others also prevents induction into the delay portion of the coil.
This even matches the familiar "confirmed" winding configuration that SM and Tao gave us, but I think the coils were mislabelled on purpose by SM to throw us off, as he knew we could figure out his winding configuration eventually.
The FTPU looks like there may be a different (twice as long) delay on the bottom as on the top...
Let me know what you think!
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
