HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
0 Members and 2018 Guests are viewing this topic.
jdurban
Quote from: wattsup on April 24, 2008, 11:41:34 AM
@JD
You say there is no battery because you do not conceive seeing him taking off all that tape. Who said you have to take all the tape off. If I had a battery in the small taped TPUs it would be under the first tape I removed, not the last. No one was every allowed to take one apart besides the cut-away. On the smallest taped TPU, you would have to take a look to see if a part of that wrinkled tape covering is newer then the rest. That would explain battery change. All the other devices all have their places for a battery. But right now I am concentrating on the FPTU.
@EM
I have been using the new VirtualDubMod with all those filters. But I really miss being able to zoom in and then pan around the image. Then do some forward/backwards movement. It's too bad I cannot pan or there is no scroll bars.
As for no pulsing. This is DC and if there is no pulsing, there is no primary to secondary coupling. The toroid would not produce current on that 8 laced black wire and you would just produce heat.
Let me show you somethings.
Photo ftpu-maybe-reed1.jpg shows A and B point. The A point is a connection with some spaghetti tube right next to the toroid and the magnet area. There could be a reed in there easy. The B point direct to the top of the toroid are where there is a same spaghetti connector just hanging over the toroid. You cannot see it in the photo because you have to play around with the image to see it but it is there. A is on the right half, B is on the left half. Why would you have this there?
Photo ftpu-battery1.jpg points to the underside center hole that is very bright for a hole. When you look closely, you will see what looks like the positive of a B type 1.5 volt battery. You can also see there is a wire there that just stops on the surface of the battery. Have you ever soldered a wire to a battery. lol
The picture you posted showing the three white wires rising from the center is very good also. When you follow these wires, you will see they are connected to the primary in the way shown in my animation. But that is not important right now.
I asked about Zener diodes on a previous post that I referred you guys to the Tesla Project thread. In the Tesla Project thread, we have shown that you can energize a circuit, make a short, and use the flyback. Making two movements for the price of one. And all that's required is a short. But I do not think SM was that advanced to think of the flyback.
The FPTU in probably using two loops, one low level loop that is isolated from the higher voltage loop coming from the primary/secondary action. The isolation is taking place in the toroid by the black wire that is laced through the toroid holes. I will get into this aspect soon but need a few more pieces of the puzzle. Looks like
Meanwhile............
1) If there are any EE guys like @eldarion that can make a quick mock up of the FTPU rings using two iron wires and a secondary wire and wrap four primaries of maximum 12 turns per quad, then connect as per the animation  and do some alternating pulsing and measure the secondary output, this would help incredibly at this stage. You can then try other primary connecting schemes and polarities to finalize this section.
2) If there are any guys that have a virgin toroid core, make 4 holes on each half, lace a thin multi-strand wire through the holes, then wrap two coils on each half and do some testing, this again would help advance forward.
It's possible of course and I am without any ideas on how one could get this thing started up without some form of excitation but knowing that the energy that this device has to tap to run once running is so potent that I am certain that it must be also available to jump start the device itself. It may be a harmonic of the Schumann cavity that is targeted and used as a primer to get humming.
I apologize to all that find my demeanor or approach to be close minded or quick to discount SM references. I just try to find the path of least resistance and having dealt with many, many inventors over the years I have developed a pretty good hi Q B.S. filter and its difficult sometimes to remain open minded. Sometimes I confuse an open mind with an open loop. Damn that was good. Will that fit on a bumper sticker? ;D
Windows has detected a mouse movement and will now reboot.
Grumpy
So, what is known of this original European device?
        -Frank Edwards
innovation_station
@sparks
i just assembled 2 crystal radioes this past weekend with my son  funny thing ....
well just got back from the city bought a few more things......
but the coolest things were the reed switches wich the lady at the shop said "you just put a magnet on it "  kinda pricey tho 7bucks each and picked up my first fets to play with irf840 grabed 12 of em too
and a tonne of other toys to play with....
ist
@ grumpy i bet magnets were involved...  maybe bar magnets?
hartiberlin
Quote from: Localjoe on April 24, 2008, 01:33:46 PM
@Sparks
Better us than the six grader tho..  In my mind you always have to work for something, if you dont shed some pain and sweat you didnt really work for it.  as well its much better if one of us gets the shit zapped outo of us or rad burns than some gradeschooler trying a project becase his family cant afford power anymore... This is a sad double eged sword but it has to be done.
I can tell you this, my Girlfriends dad who owns a family dairy farm paid approx 2.00 a gallon for diesel last year to fillt here fuel tanks below ground for the year.  Small farmers dont make a whole lot so now take this, this year it will cost him over 5 dollars a gallon to fill the tanks for the year. That difference in gas was there profit  .... now tahts gone and the poor guy and his father and there uncles work all day just to keep the animals allive and milk them. But there pay checks have gotten significantly smaller. 250 - 300 dollars a week isnt that much when your use to about 600 a week.  When i see things like that happenign in life.. The cons of getting burned or shocked seem pretty  insignificant.
PS.. when grandpa brought up the fact that he would buy horses and dig his old plows up if it came to it.. the issue kinda hit home with me
All farmers which have enough space and some wood lying around should use this
free type of energy generation:
http://journeytoforever.org/biofuel_library/methane_pain.html
http://www.biomeiler.at/
Free energy from the nature.
Regards, Stefan.
BEP
@jdurban,
Were you a witness to the use of the ampprobe? I ask because I would like to determine which cardinal direction the probe was facing when he found a good reading. If you weren't perhaps you can look at that video and determine it from other knowledge?
Thanks
