HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
Bruce_TPU
Hi Wattsup,
I do not think that Spherics meant that SM wound that EXACT sat ind switch.  I think he was saying that SM used the toroid as shown, in "much the same way."  To provide two needed items.  1.)  HV pulses 2.) fast rise times.  SM did not have the luxury of the electronics of 2008.  SM said that it took them 10 years to work the circuit from tubes to SS.
Just something for everyone to chew on.   ;)
Cheers,
Bruce
Feynman
Yeah, I also think that's possible these toroids were used to "shape" the waveforms.  ie.  Improve rise times, etc.  Vacuum tubes have very fast transit times (<2ns) but MOSFETs and transistors do not (25ns-700ns).  Just a thought.
starcruiser
Just a thought here, what if the torrid is just a transformer that is used for an oscillator or just a transformer that is wound with opposing coils?
Regards,
Carl
khabe
 I dont like to break in on your argy-bargy discussion but there are some of my observations during few past years.
When Mannix(?) published messages from Steven then he (S.M) told that has spent US$10K for Neodymium magnets - not any reaction from your side.
Although S.M. told about benefits of vacuum tubes ... are you up till today naive to find out some hidden ones from built by S.M. samples?
Why J.D. mentioned about boyfriend of Steven, is it part of Novel or was it like masturbation?
Are you sure anybody got even one real message from Steven Mark?
Lot of questions - hereby was only fews,
Sorry about my poor English,
Regards,
K.Habe
starcruiser
@Loner,
The large TPU has a piece of COAX in it, check the video out when he cuts it open, it is near the top if I am not mistaken.
Quote from: Loner on May 05, 2008, 02:52:48 AM
Starcruiser, That is along the lines I was thinking.
The Torrid could be used to jack up the voltage and Freq. control and the Saturated
Inductor switch would be in any cable just by placing VERY thin material against
the wire.  Put some tape over that and you  are at exactly what the patent describes.
(Well the patent specs Coax, but even a wire pair would work.)
Just a thought.
Art.
Regards,
Carl
