HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
Spoodily
Quote from: powerunlimited on April 17, 2008, 06:23:27 PM
This question is for  Mr Jack Durban,given the devious nature of SM
I believe your assessment of him is correct.Given that,
what he has said can not be
taken as absolute truth.
Is the output of the TPU ,dc at 5khz to 6khz.
Was a scope or a frequency counter ever used on any TPU to check this,
or is this solely SM saying its
Dc at 5khz to 6khz.
In one video he connects the meter backwards and it shows a minus reading this confirms
its polarized, its dc voltage but thats all I see.
Thanks for the video!!!
The system has 5-6000 Off-On-Off pulses per second.  This does not mean that one coil is producing all of the pulses in rapid succession, the pulses could be divided among several primary coils.
The system is pulsed DC fed into a transformer that has seperate secondary coils to receive half of the off-on-off pulse.  The use of two independant secondaries makes what would be an AC tranformer into two DC outputs.
The direction of the turns of the primary also affects the coils polarity in relation to its direction of current.  You can fire an "AC" system down different coils to maintain a continued flow of polarity.  All that really matters is that there is an increasing and decreasing magnetic field for the secondaries to see.
If you know that a current will be induced in a secondary coil during both the turning on and off of the primary you can use it to your advantage.  The diameter of the ring (the unit itself) is in relation to the frequency because you are trying to time the "kicks" seen on a galvanometer with new pulses.  The 'march' of current will aid itself.
Look what Tesla was getting into with resonators and standing waves (look at the power of cavitation-implosion of water and 2000 degree temps, just from vibrating a standing wave).  He was talking about knocking down a whole building or bridge by catching the rebounding wave with a fresh one.
poynt99
Again,
what is on VOB 3 and can somebody please upload it ?
Many thanks in advance.
By the way, if the Reed Relays would be really used to pulse the circuit
mechanically via vibration, the output would not be this steady.
You would see much more flickering and a Reed Relay can not reach 5 to 6 Khz,
maybe just 200 Hz , either  much less in switching rate...
So it is no way that SM used any Reed Relays in a mechanically selfoscillary mode.
Also you would have heard the switching noise from the moving reed metals...so no way he used these
as oscillators..
Spoodily
Quote from: hartiberlin on April 17, 2008, 08:12:25 PM
Again,
If you have VOB 1 and 2 you have everything.  The other VOBs are the same footage as in 1&2 but rewound and paused at certain points.  They look to be just notations for the person that recorded it.  I think J. D. mentioned that he wanted to go over it a couple times to make sure he got all the picture and sound he was looking for.
