HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
FatBird
I know some of you will disagree with this, but I really believe the following hypothesis:
Floyd Sweet just had a rotating Aether Vortex spinning between the 2 flat magnets.  Edwin Gray had it spinning inside his special tube.  Hubbard had it spinning inside his circumference of pulsing electromagnets.  The TESTATICA Device has it spinning inside the two large cans.  SM had it spinning inside sequentially pulsing control coils arranged in a Toroid.  These are just different ways of accomplishing the same thing.
That is why most of SM's TPUs wouldn't work upside down.  When he flipped them over, the spin came to a gradual stop.  That also coincides with what SM called the "INERTIA EFFECT".  In essence, SM proved that Aether will only spin in 1 direction in the northern hemisphere.  When flipped over, no Aether spin = no output.  Neither SM nor Floyd Sweet really knew the relevance of the spinning Aether Vortex.
Remember when Sweet accidentally shorted the 2 output wires & ICE formed.  Aether Spin in Coils Produces COLD ELECTRICITY!
Remember in one video where SM said "Now you tell me why it won't work upside down."  Yes, SM is a Very Brilliant Man, but at the time he really didn't understand that the TPU output power was coming from the Aether Vortex.
I think the foregoing facts are very important for a TPU Design Concept.
jdurban
Quote from: FatBird on April 23, 2008, 07:01:38 PM
Great concept!
I agree. My original thinking was that Steven's little magnet based switch was the cause of the unit shutting down when upended and sliding off center of the reed but after seeing the video prior to releasing here I noticed that the magnet stays in place. This also reinforces the fact that the TPU is not overly influenced by nearby DC flux as presented by the magnet(s).
Windows has detected a mouse movement and will now reboot.
sparks
 @fatbyrd
The aether is a fluid and the Earth pumps it around.  All we have to do is get a whirlpool going on the side of the river and it's free energy from there on out.  Now which way does that compass point?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
FatBird
Thank you for your support Jack & Sparks.
Jack, it would be of IMMENSE VALUE if you can remember which way the Compass Spun Up.  Was it clockwise or CCW?  That would tell everyone which way the Coils need to Pulse, CW or CCW, to operate properly.
SM spoke of his compass spinning up & coasting down when the TPU was shut off.  I watched all of the Low Res Films, but none of them showed a compass.
Can you remember anything on that?
Thank you Jack for all of your contributions.
Spoodily
Quote from: FatBird on April 23, 2008, 08:07:41 PM
Jack, it would be of IMMENSE VALUE if you can remember which way the Compass Spinned Up.  Was it clockwise or CCW?  That would tell everyone which way the Coils need to Pulse, CW or CCW, to operate properly.
I'll give you a hint.  The turbine and rotating magnetic field effect happens because the 2nd secondary's flux pulse (received from the collapsing magnetic flux from turning its primary's off) is routed into the next firing primary.  The second secondary coil is preferable to use because the next firing primary will have a neutral core to pulse to.  Not all wires are closed loop at the same time, this would cause energy loss.  Copper is awesome because it is invisible to magnetic flux when not closed loop.
The primaries are side by side and have the same polar direction.  This means that the same flow of magnetic flux will be maintained for every pulse.  The wiring is uniform around the ring, the most important part is to have the coils wound in the appropriate direction so the primaries pulse the correct way and the secondaries receive the flux in the right way.  The directing of the secondaries flux pulse is to be complimentary to the flow of the system.
When you remove the input power of the capacitors into the primaries (ie: turn the unit off), the system is winding down 'like a turbine' until the pulses lose all of their 'momentum' and equilibrium is reached.  This is because one pulse to a single primary causes a rolling pulse that is recycled by a secondary coil, fed into a primary that pulses and that pulse is received on a secondary whose pulse is fed back into primary and so on.  It keeps pulsing until there is no more energy, the energy to maintain the system is from the capacitors and batteries.
The primaries can double as secondaries, wires can be reused for dual purpose.  This simplifies the amount of wiring for a rotational firing of the primary coils and having two secondary coils per primary.
In normal operation, the pulse from the secondary is paired with a fresh spike of current from a capacitor.  The correct timing of the pulses will created bigger and bigger pulses on the secondaries.
The same principle behind shaking a building down with a tiny oscillator.  It uses very little energy to get a big result.
