HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
0 Members and 2014 Guests are viewing this topic.
sparks
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
Sparks,
I see, that you still do not see.    Still the same ol' stuff.
Chef is very wise person - very knowledgable.  You don't see that either.
As for the spinning aether, it may not be required as you state but I'm sure it would help.   Of course no one wlll ever make anything by sitting at the keyboard - that I know from experience.
G
P.S. I'm starting top agree with Marco - this IS becoming the joke of the century.
Quote from: Chef on April 27, 2008, 07:38:43 AM
Quote from: sparks on April 27, 2008, 07:26:07 AM
@ Chef
     I am not saying that SM's design didn't work.  It is just poorly designed and replication of a poorly designed machine is not going to make a better machine.
  Take a look at SM's fingers and all the radiation burns.  You don't need to have a rotating aether effect to get free energy.
As i see you already have many free "energy" to post every day new theorys, and talking lot of nonsense here.
Quote from: sparks on April 27, 2008, 08:26:20 AM
Nonsense Prove it  !
        -Frank Edwards
wattsup
@OzOnE
Good observations and questionings. Here is my take on the white wires going vertical up the drum of the spool.
If there was a winding on the drum, and if the white vertical lines were from the light reflecting on the drum, then that white line should have shown the winding also, but it is not. Also, if the center white wire was a reflection, why would there be a shadow on the right of the front center wire. Also, on the front center white wire you can see shadows of the output wires (from the right) and the shadows curve on the wire showing the wire is round. Also, when you look at where the wire rises through the spool ends, it goes through the end at the same point it touches from the inner side. All these are consistent with wires, and not reflections.
Now all this does not mean there is no winding on the drum. That would have been wound before anything else and those white wires could be seen on top of the winding. But at this stage I don't know. Also realize that the inside of the spool drum could be used for other components as well as to harbor many connection points. I have already seen at the underside hole what seems to be one end of a C type battery (I think I said B type on a previous post).
Actually, my next exercise will be to follow the wires as well as can be done and make an overall wiring diagram. It just gets complicated when you have two levels with two sides each plus the toroid, etc. Kind of  like playing 3-d chess with a rotating chess board. Spock, where are you................................lol.
@sparks
If you could just keep your theories to yourself for one more week and use that week to help us with the observations, it would be greatly appreciated. You may realize that bringing in concrete, helps build the foundation, and can also be fun and rewarding. It's your choice man. Or, if you absolutely cannot hold back and have to ditch it out, make sure it is relevant to a specific part of the device. Say "Regarding part xxx  of the xTPU, here is what I think.". By the way, we don't have to prove anything when it is up to the proponent of an idea to spell it out clearly.
@All
FTPU and Toroid Dimensions
OK I did some dimensional measurements using the Toroid left terminal on the toroid bracket as the base and considered it to be a 1/4" terminal. Plus consider SM lifted the FTPU with one hand and all finders extended around it. Try it yourself over a ruler. It will depend on actual finger length but you will get my point.
FTPU Spool Diameter: 4.5" (Not the diameter with the outer rings installed.)
FTPU Spool Height: 1" or 1.25"
FTPU Toroid Outer Diameter: 2.0"
FTPU Toroid Inner Diameter: 1.0"
FTPU Toroid Height: 0.375" or 3/8"
If anyone has any corrections, please do.
FTPU RINGS
We will have to look at this again as I think there is something else happening there. Needs more observation.
ADDED:
@Grumpy
There is nothing wrong with trying to get as many facts on the table before doing a build. Such quick action has already cost alot of time on so many angles. I would rather spend two more weeks studying then two more months running after nothing.
cell1
ATLANTEX, you find the file here.
http://www.mediafire.com/?1ptldlw1bfl
Steven Marks Tpu Nachbau, Freie Energie, Perpetuum Mobili, Nikola Tesla (Erdbatterie).pdf
BEP
Quote from: wattsup on April 27, 2008, 01:26:58 PM
The above and the spool height of 1.25" match the 'all plastic' spools of magnet wire at my place of work. The wire is used there for small motor rewinding. A 'C' battery wouldn't fit in the center hole without the hole being drilled out considerably. The only battery I can think of that would fit, length and diameter would be an 'N' style as used on dog collars and remote controls. There are different types but are generally either 1.5 or 12 volt. Different types of capacitors would fit, as well.
