HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
shimondoodkin
every one of the TPUs are buzzed.
every different TPU had little different frequencies (not sure:the larger so lower frequency) =
maybe there was some equal cycles per second in all of the TPUs.
when  the TPU was used(i.e.: connected to lamp(s)) then some of the frequencies disappeared.
as the TPU started one buzz frequency was rising slowly in form of a slow sine wave from near 2300Hz until it reached a lower large frequency(4300Hz) and then like stayed there. (not sure:i think i have seen it in the largest TPU as he tuns it on).
idea:maybe to connect audio from PC with a real oscilloscope so you can see the phase or something or none.
Feynman
Best trick would be to do like 4-pole low-pass/high-pass filters on the frequencies in question, using Ableton or Cubase in your computer.  Then you will be able to see the waveform within the spectral band you choose.
Peterae
Good work guys, work on this as much as possible because it maybe the only true information we have that tells us how it works.
Peter
MACEDONIA CD
hi to all
i have read some  here  i like to say something yes  tpu is make  noise there and  make     5000 or 6000 cikle per scend  yes   is true make  that
my test  i have send  video cilp i like  to show that  what is hapend   when  im put  small permanent magnet      and  you  seee there    is increase  the  v  and   milli amps    and   the input  v  and  milli amps  going down   when  is increase  the  v  and  milli amps  on the   out coil
<<whit that i like to provet  is   that  s.m  when  is put small agnet then  s  increase the out power  only  whit  small per mag
and  ather     simple  explane   when i put  my permanent magnet      my  toroid is start  to vibrattions  like  speaker  coil AND    YOU  SEE  THE  S.M  SAID  HIS DIVICES IS  VIBRATEDE      BEACOISE   THAT SMALL PERMANNET MAGNETS
I LIKE TO SEE  MY  VIDEO CLIP  AND  SEE  WHAT IS  HAPEND   IN  THE  MY  OSCILOSCOPE  WHEN I PUT   MAGNET S   IN THE   180%  OF MY TOROID
PS   YES MAGNET  CAN  AMPLIFAED  POWER  YES  IS   HELP TO  PRODUCED  VIBRATIONS  >
AND    WAY S.M SAID   6000 HZ   HM LET SAY YOU HAVE   60 HZ  IN     AND  YOU HAVE   100?= 6000 KICK WHIT  DC  OUT   STRANGE  IS    ;) ;) :D
YOU HAVE    AC  VOL.  WHIT  DC  VOILTAGE   PULSING 6000 TIME PER SCEOND
BUT  HOW TO MAKE THAT
EMdevices
Hi Mac,
I like your experimental results.  It's definitely a magnetics sort of an effect involving toroids, iron wire, biasing magnets, etc..
I don't want to say too much right now, cause I might have to retract it later, but I hope to experiment along these concepts this weekend, to verify some concepts.
EM
