Roll on the 20th June
0 Members and 126 Guests are viewing this topic.
hartiberlin
Hmm,
regarding the siphon, the graphics seems
plausible, but I wonder how much kinetic energy the water really has,
which comes out of the last right tube.
Does it really have the kinetic energy as if it has been falling from the top of its
tube ?
A siphon to my knowledge only works due to sucktion,
cause there is somekind of a vacuum inside the pipe that transports
the water up..
Maybe this vacuum will brake the speed of the falling water on the very right output tube side ?
infringer
No idea really but is it possible that the water could stop at the very point of the fulcrum dunno if this would be helpful but there there is really no weight then it could be emptied into the buckets or whatever just thinking outloud here...
My logic may be off but so what I felt the need to post it sorry for not liking math so much ...
I also developed a forum dedicated to archers design nothing special but it will be heavily moderated so that there is negatory on the negative comments...
Those with a positive attituide are welcome to join pm me for info.
But this can only be done under the condition that you still visit this forum and do not leave ....
Hartiberlin has went through far too much trouble to loose members. So I will keep it a strictly archer design forum...
looking for redriderno22 as well :P
-infringer-
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
noonespecial
Quote from: broli on June 01, 2008, 04:48:59 PM
"The 9" lever is mounted further from the center of the crank shaft so that the arc is larger to pass the weight by gravity to the 12" arm in the raised position and receive the weight in the lowered position."
Could you please clarify that a bit more. What do you exactly mean  "further from the center". And what is the magic bottom left weight doing.
If you imagine a typical car engine crankshaft. The 9" arm needs a greater arc so its connection point to the crankshaft would need to be further from the center of the crankshaft. As the crankshaft turns, it moves the arm through a greater arc.
The weight on the bottom (1 weight shown in 2 different positions) is how the arms are raised back to their original position. When the 2 lb weight is descending on the 12" arm it lifts this 4 lb weight from 7:00 to 1:00. Then the weight in question falls, lifting the 2 lb weight (which has just been tipped back to the 9" arm) and both arms back to the starting point.
onesnzeros
Quote from: The Eskimo Quinn on June 01, 2008, 05:29:17 PM
come all without
come all within
you not see nothin like
The Mighty Quinn
Archer, nice siphon diagram. It seems to imply something but I have no idea what. If it implies that it breaks Newtonian laws then you are wrong. I will prove you wrong, All you have to do is explain your dellusion to the forum and I will pick it apart and expose your ignorance so that others will not make the same mistake. Good luck on saving the world.
onesnzeros
b0rg13
Quote from: onesnzeros on June 01, 2008, 08:06:22 PM
onesnzeros
hmm whats the point in picking apart some ones ideas?...after all the world is flat right ?....or did some one have an idea it might be round?.hmmm
...and saving the world ? lol...the planet sure dont need saving it will find its own balance and stomp you and any other offenders out like a bug, the ones who need saving are the offenders and rulers who insist on milking the people for every dime they can, eventually the the people will one day wake up and get sick of the bullshit and stand up and hang them all, personally i cant wait for that day.  ::)
lets just say for shits and giggles archer has a working device, so what ?,yeah it would be nice.
..and lets say he does not.. oh well, to bad, the planet will still do its thing with or with out it.......why are you so worried archer might have something workable ?, do you work in a gas station or something ?, bummer.....oh arnt they screaming that oils runing out any way?...maybe you could mow lawns or something ?... oh crap thats right gas is running out. i guess your screwed.
if you want to get out of the rat race,you have to let go of the cheese.
